23784 Discussions
PCI Memory & SM Bus Controllers (Yellow Triangle): Not Finding drivers to update
Nuke615
I recently did a complete partition wipe and clean-install of the Windows 10 operating system on a Dell XPS 8910.  The restore worked well, but when I checked Device Manager, I found that the PCI Memory & SM Bus Controllers did not have the driver updates they need (see screenshots).  I tried the device manager update utilities, but they could not find any drivers. I then utilized both Dell and Intel's support assist.  There were 6 updates for Dell, and 2 for Intel.  All these updates were installed and completed successfully, and I rebooted.  However, the triangles are still there, and I cannot locate the correct drivers to install manually,  or figure out how to correct this.  I know these are crucial components, and I would like to get these drivers updated.  Can anyone please direct me to links to the correct drivers for the devices shown, or advise me with details as to how I should proceed to correct this issue?
Thank you so much for your expert guidance and assistance in this matter.  I have attached several screenshots to help diagnose the issue and all the details for the devices.  I really appreciate the assist.
Not sure what forum I should have posted this in, so I chose "Rapid Storage Technology."  Could any moderator or site administrator please place this question into the correct category if that location is an incorrect choice by me?  I have never used this site before, and am so thankful it is here.  I anxiously await a reply to my query.  Thanks again!
n_scott_pearson
Repeating from your other conversation...
Questions:
Curiously, only the ME package is considered critical. All three of these should be considered critical. They will resolve the entries you have outstanding.
Hope this helps,
n_scott_pearson
Questions:
Hope this helps,
Nuke615
Thank you so much Mr. Pearson...you are a life saver.  I assume there is no particular order to install these?  I will begin in the order you have them listed.  and let you folks know how this turned out.
Nuke615
Brilliant!  Your solution was 100% accurate, and the issue is resolved (see screen shot).  Again, thank you Mr. Scott Pearson.  Cheers! Screenshot (17)-crop.pngScreenshot (17)-crop.png
