23782 Discussions
Pale screen after reinstall windows
RДавл
After reinstalling windows my screen became pale and acquired a blue tint.
I don't know what to do.
if you want details about my laptop then write, thanks!
Stefan3D
Yes, details would be helpful. If you can't create a report with https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility for Windows* then link to the manufacturer's specifications page.
Make a photo of the messed up screen with a smartphone.
At which point does the white screen appear?
Can you see some BIOS messages?
Can you see spinning dots or a loading bar when Windows starts?
Can you see the login screen?
Can you start your laptop in safe mode?
https://www.digitalcitizen.life/4-ways-boot-safe-mode-windows-10 https://www.digitalcitizen.life/4-ways-boot-safe-mode-windows-10
RДавл
Hey, Stefan.
Make a photo pointless because you will don't see the problem. I set the contrast settings to almost maximum and the picture looks not bad, but gives a lot discomfort.
Pale screen appear after reinstall windows.
No I don't see any Bios messages.
Can you see spinning dots or a loading bar when Windows starts? - YES
Can you see the login screen? - YES
Can you start your laptop in safe mode? - YES
I hope for your help, thank you.
RДавл
I did it, but nothing changed.
maybe I misunderstood something?
Stefan3D
Now you have eliminated a bunch of suspects, namely all third parties' services.
The culprit seems to be the graphics driver.
If you upload the aforementioned SSU report, we can recommend alternative drivers.
RДавл
Hey, Stefan.
this is what you need?
Stefan3D
Your Intel graphics driver is out-of-date
Download https://downloadmirror.intel.com/27267/a08/win64_154037.4835.zip https://downloadmirror.intel.com/27267/a08/win64_154037.4835.zip
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
If that doesn't help: your BIOS is also outdated
Get latest from https://www.asus.com/Laptops/X555LD/HelpDesk_BIOS/ X555LD BIOS & FIRMWARE | Laptops | ASUS Global
BIOS flashing is under your own risk
If you need help with that, ask at https://rog.asus.com/forum/ https://rog.asus.com/forum/ for further help.
RДавл
It doesn't help me, but before i try to update my windows, i want you to check my SSU again, please.
Maybe i incorrectly installed intel driver. Thanks.
Stefan3D
You have installed the most recent driver correctly, the log confirms that there are no errors.
