22946 Discussions
Eizo screen for HP Pavilion
cmoge
Will HP pavilion IntelCore i3 5010U 2.10GHz HD Graphics 5500 be able to drive an Eizo screen CG2420 (1920*1200) with the supposed high level oh quality ? Thanks
Thank you very much for sharing your issue with the Intel Communities Team, noegom.I will be more than glad to assist you further.
Allow me to share with you that the https://ark.intel.com/products/84697/Intel-Core-i3-5010U-Processor-3M-Cache-2_10-GHz?q=Intel%C2%AE%20Core%E2%84%A2%20i3-5010U Intel® Core™ i3-5010U will support 2560x1600@60Hz via HDMI® 1.4 and 3840x2160@60Hz via DisplayPort™ as a result, the screen resolution of thehttp://www.eizoglobal.com/products/coloredge/cg2420/index.html# tab02 Eizo* CG2420 should be supported by your system nonetheless, I suggest you get in touch with http://www.dell.com/support/home/cr/en/crbsdt1/products DELL™ Support to discard any hardware limitation set on the mainboard. Additionally, you can reach https://www.eizo.com/support/ Eizo* Support to verify any compatibility issue.
Antony S.
