23466 Discussions
Pc wont display anything with new Motherboard
ZTemp
Hi i recently bought a new motherboard (asus H81M-plus) and it wont display anything using my i7-4790k cpu which is on the supported list of the motherboard and the bios is up to date . I used an older cpu cpu though and worked fine . So any ideas ?
Stefan3D
Clear CMOS after changing a processor.
Check all iGPU configurations in BIOS as described at https://www.asus.com/de/Motherboards/H81MPLUS/HelpDesk_Manual/ H81M-PLUS Manual | Mainboards | ASUS Deutschland
Max. CPU Graphics Ratio
GPU Boost
CPU Graphics Voltage
Graphics Configuration
Allows you to select a primary display from iGPU, and PCIe graphical devices.
Primary Display [Auto]
Allows you to select which of the iGPU/PCIE Graphics device should be the Primary
Display. Configuration options: [Auto] [iGPU] [PCIE]
iGPU Memory [Auto]
Allows you to select the amount of system memory allocated to DVMT 5.0 used by the
iGPU. Configuration options: [Auto] [32M] [64M] [96M] [128M] [160M] [192M] [224M]
[256M] [288M][320M] [352M] [384M] [416M] [448M] [480M] [512M] [1024M]
Render Standby [Auto]
Allows you to enable or disable Intel® Graphics Render Standby support to reduce
iGPU power use when the system is idle. Configuration options: [Auto] [Disabled]
[Enabled]
iGPU Multi-Monitor [Disabled]
Set this item to [Enabled] to empower both integrated and discrete graphics for
multiple-monitor output. The iGPU shared system memory size will be fixed at 64MB.
Configuration options: [Disabled] [Enabled]
