22754 Discussions
Please help! HD Graphics 4600 custom resolution is not working anymore after Windows upgrade 8.1 > 10
JSchw12
Hello!
I have a severe problem: I have been using an Eizo CG 277 27" display attached to a Samsung Ativ book 8 laptop (which also has a GeForce GT 750M) via HDMI for the last 1.5 years. I had it working with a custom resolution of 2560x1440 at 30Hz (60Hz did not work) added back in 2014 and since then did not change it and it worked fine all the time.
Today after upgrading the system to Windows 10 (from 8.1) it must have updated the graphics driver too, because that resolution is not available anymore, and trying to add it manually via 'custom resolution' does not work anymore, I get an error mesage that it would 'exceed the bandwith'. I know that it does NOT, because I have been working with the exact same hardware for a long time, and I really need this to work again as soon as possible!
This is really critical and I would really appreciate any fast and useful help to sole this issue!!! I've seen that many people are having problems with this hardware combination, but I never had until today and maybe I could just get an old driver from 2014 back from somewhere? I couldn't find one on the intel website, though.
Thanks for your help!!!
IUman
Hello custom_jana,
Thank you for joining the Intel communities.
Please try updating the Intel® graphics driver, you can download it at the following link:
https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen]
Ivan
JSchw12
Hello Ivan,
thank you for your answer. I have downloaded the driver from the link but unfortunately it shows the exact same problem (bandwith error, again which is not true because it worked perfectly fine with the older driver...).
In fact, the driver that windows installed during the upgrade process seemed to be already a little bit newer than the one that you suggested:
downloaded driver: 20.19.15.4300 from 2015.10.01
from windows installed: 20.19.15.4331 from 2015.11.18
It seems that I do not need a newer driver with reduced functionality, but rather a driver from around july/august 2014 that just works...
So.... thanks anyway, but I still need to get my 27" screen working with its native resolution again
Any help still very appreciated!
IUman
All the drivers we have available for the Intel® HD Graphics 4600 you can check them at the following link:
https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors Drivers & Software
Ivan
