22654 Discussions
Please urgent help about flashing a graphic card with possible malware infection.
ICust54
My graphic card is 946gz and some time ago it lost several funcionalities(e.g. changing resolution on loading linux live cd-s) and also the pc itself boots windws xp with a strange delay with a blinking underscore showing up for more than a minute or even more.After several reinstalls of op.system I am sure that annoying losing of internet connection and desktop unresponsiveness are coused by some malware installed on pc hardware firmware or peripheral hardware firmware.At this point I just think to throw away all my pc equipment including monitor, printer usb sticks,wireless adaptor and start again from scratch but I would try to flash the graph.card bios(not system bios!-already done) before all that happens.I downloaded the necessary files from intel downl.site but now after I run the exe. file from dos cd (not windows command prompt)it doesn't give me the possibility to add the configuration file and the vbios data file to the installation process.So does somebody know what I have to type after I type the name of he executable file?Thanks!
Allan_J_Intel1
Thanks for joining the Graphics community.
I understand you are trying to update graphics card BIOS.
Please bear in mind, in order to update video BIOS, you will need computer BIOS that includes an update for the graphics BIOS. This update is available through your computer manufacturer. If you have an Intel(R) Desktop Board you could access the link below and search for your motherboard model that way you can obtain latest motherboard BIOS:
https://downloadcenter.intel.com/default.aspx https://downloadcenter.intel.com/default.aspx
For additional information about video BIOS go here: http://www.intel.com/support/graphics/sb/CS-029985.htm# 2 http://www.intel.com/support/graphics/sb/CS-029985.htm# 2
Allan.
