22649 Discussions
Power Limit in Arc A750
Vectos
By default, my ASRock A750 arc came with a power limit of up to 180W. I would like to know if I should leave it at 180 or if I should set it to 216W.
Considering that my power supply has 1 cable that splits into two 8-pin cables,
I heard that the PCI provides 75W of power and an 8-pin cable provides 150W.
Is it safe to leave it at 216W?
Power supply: MSI MAG A650BN 650W 80PLUS BRONZE
cpu: i3 10100f
DeancR_Intel
Hi Vectos,
Thank you for posting in the community! Apologies for the delay on my response.
The Total Board Power (TBD) for your GPU is 225 W, this data comes from intel. (TBP) is the power draw of a graphics card under heavy load, like gaming. For accurate max power details of an Asrock GPU, I suggest contacting Asrock as well.
Here's the link for reference:
Intel Arc A750 Graphics Product Specifications
ASRock > Support
Dean R.
Vectos
In arc control I can leave it at a maximum of 216w
DeancR_Intel
Hi Vectos,
225 Watts is the max power for your GPU, I suggest contacting Asrock as well just to be sure.
More information about overclocking
How Can I Overclock My Intel® Arc™ GPU Using Intel®...
Here's the link for reference with the specs of your GPU:
Intel® Arc™ A-Series Graphics Processors Power Terminology
Link for AsRock support:
ASRock > Support
Dean R.
DeancR_Intel
Hi Vectos,
Dean R.
DeancR_Intel
Hi Vectos,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
