23847 Discussions
Problem With Updating Drivers
I've been trying to download the latest drivers for my system, an inspiron 1525 laptop with 32-bit Vista. My graphics card is an Intel 965 Express Chipset.
When I try to run the driver update utility, I get this error under driver:
A customized computer manufacturer driver is installed on your computer. The Intel Driver Update Utility is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your http://www.intel.com/support/oems.htm computer manufacturer for the latest driver for your computer.
It also says my system is a GM965 card, and that my driver version is 7.14.0010.1409.
Attempting to use the categories system will lead to a driver that should work, but won't install.
Are my drivers up to date enough? Why can't I install any?
If you are using Intel Generic Driver, it may not work.
It is best to get the driver from the Dell Support Site.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
All the best,
Kind Regards,
Aryan.
