23526 Discussions
RAID-1 rebuild destroyed my data
A few years ago, I had installed Win XP on a single hard drive (on the SATA 0 port) and had to tell the Intel Matrix Storage Manager to use Combination mode since I couldn't get the F6 driver to work while doing the install but still had two other hard drives (SATA 2 and SATA3) as part of a RAID1. A couple of nights ago, I used two new hard drives (on SATA 0 and SATA 1) as part of a new RAID1 to install Windows 7 and told BIOS to use RAID hard drive settings instead of Combination, since Windows 7 already had the necessary drivers. While rearranging hard drives, I accidentally plugged in the old Win XP hard drive into the SATA 2 port, so the Intel MSM told me the second RAID needed to be rebuilt. I realized my mistake, so I put the correct hard drive back into the SATA port 2, but the Intel MSM still said it had to be rebuilt. After installing Win 7 on the first RAID, I noticed that the second RAID just showed all unallocated space. I downloaded the Intel Matrix Storage Manager software, and right away, it started rebuilding. After rebuilding (the two hard drives that had already been part of) the second RAID1, I checked and it still looked to just have unallocated space.
I even ran TestDisk, and it didn't find any partitions on either drive. I lost a lot of data. What did I do wrong? What did Intel's Matrix Storage Manager do when it "rebuilt" the drives? I wonder if it called the RAID on SATAs 2 and 3 "Array_0000" before, but then renamed it to "Array_0001" after the new RAID was created on SATAs 0 and 1, which could mean that it's "rebuild" was actually a new create.
Note: The report below shows Array_0000 rebuilding, since I tried putting the Win XP hard drive back in, but it also didn't see anything on the RAID-1 on SATA ports 2 and 3. Miraculously, the RAID-1 on SATA ports 0 and 1 seems to be working fine even though Intel's MSM thought it needed a rebuild after temporarily putting the old hard drive back in SATA port 0.
----- Here's the first part of the system report -----:
System Information
Kit Installed: 8.9.0.1023
Kit Install History: 8.9.0.1023, Uninstall
Shell Version: 8.9.0.1023
OS Name: Microsoft Windows 7 Professional
OS Version: 6.1.7600 Build 7600
System Name: SERENITY
System Manufacturer: Dell Inc.
System Model: 0YC523
Processor: Intel(R) Pentium(R) D CPU 2.80GHz
BIOS Version/Date: Dell Inc. A03, 01/03/2006
Language: ENU
Intel(R) Matrix Storage Manager
Intel RAID Controller: Intel(R) ICH7R/DH SATA RAID Controller
Number of Serial ATA ports: 4
RAID Option ROM Version: 5.0.0.1032
Driver Version: 8.9.0.1023
RAID Plug-In Version: 8.9.0.1023
Language Resource Version of the RAID Plug-In: 8.9.0.1023
Create Volume Wizard Version: 8.9.0.1023
Language Resource Version of the Create Volume Wizard: 8.9.0.1023
Create Volume from Existing Hard Drive Wizard Version: 8.9.0.1023
Language Resource Version of the Create Volume from Existing Hard Drive Wizard: 8.9.0.1023
Modify Volume Wizard Version: 8.9.0.1023
Language Resource Version of the Modify Volume Wizard: 8.9.0.1023
Delete Volume Wizard Version: 8.9.0.1023
Language Resource Version of the Delete Volume Wizard: 8.9.0.1023
ISDI Library Version: 8.9.0.1023
Event Monitor User Notification Tool Version: 8.9.0.1023
Language Resource Version of the Event Monitor User Notification Tool: 8.9.0.1023
Event Monitor Version: 8.9.0.1023
Array_0000
Status: Rebuilding
Hard Drive Data Cache Enabled: Yes
Free Space: 0 GB
Number of Hard Drives: 2
Hard Drive Member 1: SAMSUNG HD154UI
Hard Drive Member 2: SAMSUNG HD154UI
Number of Volumes: 1
Volume Member 1: SerenityRAID0
Array_0001
Status: No active migrations
Free Space: 0 GB
Hard Drive Member 1: WDC WD5000AAKS-00TMA0
Hard Drive Member 2: WDC WD5000AAKS-00TMA0
Volume Member 1: RAID 500GB
SerenityRAID0
Status: Rebuilding: 2% complete
System Volume: Yes
Volume Write-Back Cache Enabled: No
RAID Level: RAID 1 (mirroring)
Physical Sector Size: 512 Bytes
Logical Sector Size: 512 Bytes
Parent Array: Array_0000
RAID 500GB
Status: Normal
System Volume: No
Parent Array: Array_0001
