22940 Discussions
Problem of 12th gen H-series intel Xe internal graphic frequency lock 100mhz
luxiaoshi
My computer is Asus Zephyrus M16 with I9 12900H and Rtx 3070ti
I found that when I watch 4K video on YouTube and Bilbili video platform, the xe graphic always on the 100% occupied rate, then I disabled the rtx3070ti and found that xe graphic works always on the 100Mhz
xe driver is 101.1631, the latest version
Here are some other users using the same generation CPU reported the same question and it seems already last for a long time.
https://tieba.baidu.com/p/7794310670
https://tieba.baidu.com/p/7726322122
Alberto_R_Intel
luxiaosh, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only deliver support in English language, so, we will not able to understand any of the information that is shown in a different vocabulary.
In order for us to provide the most accurate assistance on this matter, first, we just wanted to confirm a few details about your system:
Is this a new laptop?
When did you purchase it?
You mentioned: "the xe graphic always on the 100% occupied rate, then I disabled the rtx3070ti and found that xe graphic works always on the 100Mhz" Was this computer always showing this same behavior, or was it working differently before?
When did you notice this problem?
Did you make any recent hardware/software changes besides disabling the rtx3070ti that might cause this issue?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
luxiaoshi
Reply,
This is a new computer and my purchase date is February 2022. This does not necessarily happen, it happens randomly. I noticed this situation because I found that the video on the web page was stuttering, and the graphics card used by the browser was not an rtx discrete graphics card. Then I disabled the discrete graphics card and used the stress test software to confirm the problem, and then I got the screenshot I sent. Recently made hardware and software changes there is a patch KB5012643 that updates Windows 11, at home. If the ssu report happens again, I will post it later
Jean_Intel
You mentioned that you made hardware and software changes; however, you only stated installed the patch KB5012643. We want to confirm which hardware change you have performed. It will help us determine if this could be the root cause of your issue.
Also, please provide us with the SSU report, as this provides us with vital information that will help us with further assistance for your issue. Remember to check all the options in the report, including the one that says "3rd party software logs": (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html?product=91...)
Jean O.
Alberto_R_Intel
Hello luxiaoshi, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
luxiaoshi
I reinstall the up-to-date official drive instead of oem provided one, It seems do not lock frequency again.
Alberto_R_Intel
luxiaoshi, Thank you very much for letting us know those results.
"I reinstall the up-to-date official drive instead of oem provided one, It seems do not lock frequency again.", Perfect, excellent, it is great to know that the problem with the frequency getting locked on the processor got fixed by installing "the up-to-date official drive", and now the computer is working properly as expected.
Any other inquiries, do not hesitate to contact us again.
Albert R.
