23832 Discussions
Problem with Intel GPU Top in Ubuntu
kvanurag02
I have a question regarding the intel-gpu-top command. While measuring GPU performance on core-i5 1135G7 running Ubuntu 20.04 LTS (5.14.0-1056-oem) this is the output of sudo intel_gpu_top command.
Since 1135G7 has 2 Multi-Format Codec Engines, it shows up as Video/0 and Video/1.
But the same command in a custom yocto build Poky Linux (5.10.100-intel-pk-standard) shows this on the same machine.
There are no Video/0 and Video/1 showing up  in yocto. Is this something related to the drivers? Both operating systems have the i915 kernel driver in it.  Any help would be appreciated. Thanks.
kvanurag02
Thank you for your response. There is an alternative solution for this problem. By simply writing the intel_gpu_top command onto a file (intel_gpu_top > gpu-log.txt) we can get both of the video codec data. So I guess the issue is resolved for now. Thanks.
Jean_Intel
Hello kvanurag02,
Please consult with your Operating System vendor for updates and support necessary for your specific OS and system configuration. Remember that for the Linux operating system, most Linux-based* distributions include Intel® Graphics Drivers. These drivers are provided and maintained by the Linux* Operating System Vendors
Jean O.
kvanurag02
Jean_Intel
Hello kvanurag02,
We are glad to know you found a solution. Thank you for taking the time to share this fix.
Hopefully, it will help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
Note that if you face any similar issues, you should consult with your Operating System distributor.
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jean O.
lukeomatik
Mate, just type '1' while on intel_gpu_top main screen.
According to the help page (type 'h' while on intel_gpu_top):
Help for interactive commands:
   '1'    Toggle between aggregated engine class and physical engine mode.
   'n'    Toggle display of numeric client busyness overlay.
   's'    Toggle between sort modes (runtime, total runtime, pid, client id).
   'i'    Toggle display of clients which used no GPU time.
   'H'    Toggle between per PID aggregation and individual clients.
You want the physical engine mode, not the aggregated one.
And by the way look at archlinux wiki, gentoo wiki and other distro wikis about linux drivers and stuff, they sometimes are very helpful even tho the distro is different.
Cheers
