23851 Discussions
Problem with Intel Graphic 500 Driver
Dory
Hello everybody,
I post this message because I've a problem with the driver of Intel Graphic 500:
When I Update the driver at the last version, no problems but when I start my computer (Hp X 360 11 G1 EE) a lot of white, blue and red lines appear and blink. I have to press the power button until the login page appear.
However, if I uninstall the driver and use the Microsoft Chipset integarted, no problems.
What can I do?
Dory
I finally found the solution. I've uninstall last update with device manager.
Now I have no problems with screen and start.
Thanks everybody for your help.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Dory
You can find here what you asked me.
AlHill
Here is the latest driver for your processor graphics:
https://downloadcenter.intel.com/download/30266/Intel-Graphics-Windows-10-DCH-Drivers
Dory
Thanks but it's this one who create the bug when I start my laptop.
Dory
On the website of HP it's the same driver, not same name but same program: I've also the bug with it.
AlHill
I very much doubt it is the same driver.  The first link I passed to you was just created a week ago.
At this point, contact HP for help with their hardware.
Dory
Tomorrow, I will take some hours to call HP. If they find a solution, I will also post the solution.
n_scott_pearson
This is a laptop. If you are using a driver from the Intel site, it may not support all of the operations - especially that for on-battery/off-battery state handling - that this laptop may require. You should be using ONLY the drivers provided by your laptop vendor. If these do not work properly or are out of date, then you need to contact your vendor regarding this issue, not Intel.
Dory
