23838 Discussions
Problem with Intel UHD 750
Wiselka
Hi! I have a problem installing my graphics drivers. The program installs drivers (30.0.100.9864), but after installation it shows system error: 0x00000430. And it doesn't install the driver at all.
ClariceStarling
Valued Contributor II
Download it ... disconnect from the Internet .. then try to install it.  If that doesn't work, there's lots more advice ...
https://www.intel.com/content/www/us/en/support/articles/000027538/graphics/graphics-for-7th-generation-intel-processors.html
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
