23851 Discussions
Problem with driver installation
Nebojsac
So, i just bought a new laptop with an intergrated graphics card and when i try to install the drivers for it, the error in the title pops up. The explanation given here (https://www.intel.com/content/www/us/en/support/articles/000088393/graphics.html) isn't really clear to me so if any of you guys could help me out, it would be much appreciated.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Nebojsac
DeividA_Intel
Hello Nebojsac,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® UHD Graphics 605.
Bear in mind that the manufacturers (Acer, HP, Dell, etc) can modify our generic drives so they can work properly with their system and are the ones in charge of building the laptop. I recommend you to check with Acer to confirm if there is any malfunction with the CPU or motherboard.
However, in order to better assist you, please try the following:
1. Does this issue happen with the Intel and Acer drivers?
2. Is this issue recent? Were you able to update your drivers before?
3. Did you notice the issue after a BIOS or Windows update?
4. Have you checked this behavior with Acer?
Deivid A.
DeividA_Intel
Hello Nebojsac,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Nebojsac,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
