23654 Discussions
Problem with graphics driver updater.
ZDra
I have a problem with graphics driver updater. I installed the updater and it found my driver, when i klick on button "install", it installing and when: Failure, unknown error. So what should i do? Help!
jsing21
I think this problem due to Some error or virus in operating system(OS), I recommended to install fresh OS. If u not want to re-install OS then u may try system repair ( repairing system registry).u can found many sites( including OS website) who will tell u step-by-step "how to repair registry". u can apply method as per your own conveyance.
Hello, Zuv3dra:
I would like to gather some information in order to address this matter, so please download the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility, and attach it, with this report I will be able to confirm some of that information. I would also need from you to provide me with the Intel® Driver Update Utility version you have installed.
Amy.
Hello, Zuv3dra:
I wanted to check on your thread; were you able to track this down? Was the issue resolved? If not the case, reply back with the information requested above.
Let me know your findings.
Amy.
