23829 Discussions
Problem with ig9icd64.dll
MKreb
if I use my slicer-program ​ xyzware nobel it crash immediately with following error:
Name der fehlerhaften Anwendung: XYZ.exe, Version: 12.1.15.1, Zeitstempel: 0x5c2c63c7
Name des fehlerhaften Moduls: ig9icd64.dll, Version: 25.20.100.6519, Zeitstempel: 0x5c367841
Ausnahmecode: 0xc000041d
Fehleroffset: 0x0000000000412046
ID des fehlerhaften Prozesses: 0x33b4
Startzeit der fehlerhaften Anwendung: 0x01d4bcae96207359
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\XYZprinting\XYZ.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c341b9f860fc726f\ig9icd64.dll
Berichtskennung: 98a2d9c9-4d9c-4bcb-82ea-684baf200124
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
I have installed the newest Intel driver
My System is:
System Information
     Time of this report: 2/5/2019, 09:32:02
            Machine name: MARCUS-MAC
              Machine Id: {D2D983FF-3495-478B-992F-E391B28B90F3}
        Operating System: Windows 10 Pro 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
                Language: German (Regional Setting: German)
     System Manufacturer: Apple Inc.
            System Model: MacBookPro14,2
                    BIOS: 184.0.0.0.0 (type: UEFI)
               Processor: Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz (4 CPUs), ~3.4GHz
                  Memory: 16384MB RAM
     Available OS Memory: 16250MB RAM
               Page File: 4062MB used, 14618MB available
             Windows Dir: C:\WINDOWS
         DirectX Version: DirectX 12
     DX Setup Parameters: Not found
        User DPI Setting: 144 DPI (150 percent)
      System DPI Setting: 192 DPI (200 percent)
         DWM DPI Scaling: UnKnown
                Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
          DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
     Display Tab 1: No problems found.
       Sound Tab 1: No problems found.
       Sound Tab 2: No problems found.
       Sound Tab 3: No problems found.
         Input Tab: No problems found.
DirectX Debug Levels
Direct3D:   0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
          Card name: Intel(R) Iris(R) Plus Graphics 650
       Manufacturer: Intel Corporation
          Chip type: Intel(R) Iris(R) Graphics Family
           DAC type: Internal
        Device Type: Full Device (POST)
         Device Key: Enum\PCI\VEN_8086&DEV_5927&SUBSYS_0175106B&REV_06
      Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
     Display Memory: 8252 MB
   Dedicated Memory: 128 MB
      Shared Memory: 8124 MB
       Current Mode: 2560 x 1600 (32 bit) (60Hz)
        HDR Support: Not Supported
   Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
    Color Primaries: Red(0.680188,0.320812), Green(0.265148,0.690930), Blue(0.150891,0.055188), White Point(0.313000,0.329602)
  Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
       Monitor Name: Generic PnP Monitor
      Monitor Model: Color LCD
         Monitor Id: APPA034
        Native Mode: 2560 x 1600(p) (60.001Hz)
        Output Type: Internal
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
     Advanced Color: Not Supported
        Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c341b9f860fc726f\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c341b9f860fc726f\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c341b9f860fc726f\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_c341b9f860fc726f\igd12umd64.dll
 Driver File Version: 25.20.0100.6519 (English)
     Driver Version: 25.20.100.6519
        DDI Version: 12
     Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
       Driver Model: WDDM 2.4
 Graphics Preemption: Triangle
 Compute Preemption: Thread
           Miracast: Supported
 Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
     Virtualization: Paravirtualization
         Block List: No Blocks
 Catalog Attributes: Universal:False Declarative:True
  Driver Attributes: Final Retail
   Driver Date/Size: 09.01.2019 01:00:00, 1834808 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp: Unknown
  Device Identifier: {D7B78E66-1A67-11CF-AC6A-1121BDC2D435}
          Vendor ID: 0x8086
          Device ID: 0x5927
          SubSys ID: 0x0175106B
        Revision ID: 0x0006
 Driver Strong Name: oem86.inf:5f63e534fcbce094:iKBLD_w10_DS:25.20.100.6519:PCI\VEN_8086&DEV_5927
     Rank Of Driver: 00CF2001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeVC1_D2010 DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_Multiview_NoFGT DXVA2_ModeVP8_VLD DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeVP9_VLD_Profile0 DXVA2_ModeVP9_VLD_10bit_Profile2
  Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format
Leonardo_C_Intel
Hello MKreb Thank you for posting in the Intel Community. After looking into your system configuration I am noticing that you are using a MAC device with a Windows® 10 boot, let me share with you that as per Apple request all the support has to be requested/handle directly with them. Apple® support link: https://support.apple.com/ Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
Leonardo_C_Intel
