23083 Discussions
Problem with igfxCUIService1.0.0.0 on every bootup
DGlan
On every bootup of my Win 10 64-bit, I get the following "Information" event in Event Viewer, usually twice or more. By the way, I don't have any graphics card - so this relates to the Intel drivers/services for the graphics on my motherboard. Also, there is a running Service with Service name "igfxCUIService1.0.0.0" and Display name "Intel(R) HD Graphics Control Panel Service". Here's the event viewer message:
The description for Event ID 0 from source igfxCUIService1.0.0.0 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Log on event received User1
The "Details" are the following:
- System
- Provider
[ Name] igfxCUIService1.0.0.0
- EventID 0
[ Qualifiers] 0
Level 4
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2015-08-19T12:20:30.000000000Z
EventRecordID 1610
Channel Application
Computer Opti7010Win8
Security
- EventData
What do you think?
IUman
Please assist me with your PC model and your processor model.
Also, ensure to install any pending updates to check if this helps and update all of the latest drivers from your system manufacturer website.
DGlan
Ivanu:
My PC is a Dell Optiplex 7010 Desktop with 16GB RAM
The processor is an Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
There are no pending updates.
Also, for the included graphics, Speccy reports this:
Intel HD Graphics
Manufacturer Intel
Model HD Graphics
Device ID 8086-0152
Revision A
Subvendor Dell (1028)
Current Performance Level Level 0
Driver version 10.18.10.4252
Count of performance levels : 1
Level 1 - "Perf Level 0"
Also, Ivanu - are you an Intel employee?
EDIT - Intel's CPUID function shows this - my System Graphics are Intel(R) HD Graphics 2500
Intel(R) Processor Identification Utility
Version: 5.30.20150729
Time Stamp: 2015/08/20 21:10:42
Operating System: 6.2-9200-
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 4
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Type: 0
Family: 6
Model: 3A
Stepping: 9
Revision: 1B
Maximum CPUID Level: D
L1 Instruction Cache: 4 x 32 KB
L1 Data Cache: 4 x 32 KB
L2 Cache: 4 x 256 KB
L3 Cache: 6 MB
Packaging: LGA1155
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: Yes
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: No
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: Yes
System Graphics: Intel(R) HD Graphics 2500
Expected Processor Frequency: 3.20 GHz
Reported Processor Frequency: 3.39 GHz
Expected System Bus Frequency: 100 MHz
Reported System Bus Frequency: 100 MHz
Ivan_U_Intel
Have you tried updating your Windows 10 graphics driver?
You can download it at:
https://downloadcenter.intel.com/download/25188/Intel-HD-Graphics-Driver-for-Windows-10-64bit-3rd-Gen-BYT- https://downloadcenter.intel.com/download/25188/Intel-HD-Graphics-Driver-for-Windows-10-64bit-3rd-Gen-BYT-
This computer you have is an OEM computer and it could be limited to Windows 10 and maybe all the drivers are not available based on Windows 10, also the can be customized so you will need to get them from the DELL website.
Yes, I'm an Intel employee.
DGlan
Ivan - thanks for reply. Yes, I have tried exactly that new driver. Actually twice the last two days. I downloaded and ran it before your post above, and now after your post again a second time. No help.
On reboots just now, I continue to get the same message two or three times on each bootup.
The last bootup just now has three of them. They look the same except the last line in General is different:
Logon: 1
Received Post Shell Event 1
IUman
Please be aware that our engineering department is working in a new graphics driver, you can see more information here:
/message/320480# 320480 https://communities.intel.com/message/320480# 320480
