23528 Discussions
Problem with intel graphics, i connect to to nvidia support, they says that problems is from intel graphics, any know what i can do? intel drivers is it latest, i tryed and old driver. same problem
MCivi
AlHill
Since you have dual graphics, presumably on a laptop, you MUST use both the Intel and Nvidia driver provided by your laptop manufacturer. You cannot use the Intel generic driver.
And, you provided no information about your system.
Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
MCivi
This is need for you? and what i can do? how fix this problem?
MCivi
this is full system
AlHill
That was only part of it. We need the full report.
Also, the nvidia 940m is pretty old.
Did you use both drivers from the laptop manufacturer like I suggested?
Doc
MCivi
iam tryed old drivers version and latest but same problem, now iam downloaded drivers from acer, ill be try recomended drivers
AlHill
Then, you need to contact acer for support of their laptop and drivers, as they are supposed to have tested their customized drivers on their laptop.
Doc
MCivi
dont helped recomendet drivers, i have same problem, i will try contact to acer support
