23087 Discussions
MONITORES CON DIFERENTE RESOLUCIÓN EN MODO COLLAGE
JGil01
Tengo dos monitores de diferente resolución pero ambos puedo ponerlos manualmente desde windows en 1280*768 sin embargo al usar intel para ponerlo en modo collage una de las dos pantallas se escala a pantalla completa deformando la imagen y no puedo cambiar la resolución manualmente estando en ese modo , Hay alguna forma de bloquear la resolución de ese monitor ?
AlHill
What is the model number of your processor?
What is the model number of your laptop or desktop?
What version of Windows 10 are you running? 1909?
How is each monitor connected to your device?
Doc
n_scott_pearson
Don't you just want to extend the displays?
JGil01
I want only to make my pc understand the two monitor as one screen wich is posible on intel collage mode but the two monitors can be manually scaled to 1280 *768 , but they have diferent native resolusions like 1366*1024 and1280*1024 or something like that and when i put collage mode the resoplution puts automatically on native and i cannot changet because windows see as one unique monitor with no ajustementss
n_scott_pearson
No, simply extending your display across the multiple screens will do what you want - and do so without requiring a common resolution.
