22648 ディスカッション
Problema com Intel Graphic HD 4000 - imagem tremida em monitor externo
ABrit4
ビギナー
3,715件の閲覧回数
Olá Pessoal,
Tenho um notebook i7 com Win8 com placa onbord intel graphic HD 4000 32 mb (dedicada Geforce 2gb), eu uso um monitor externo conectado via VGA, acontece que essa placa onbord esta gerando uma imagem muito ruim "tremida" para o monitor externo. Alguém sabe o que ta acontecendo?
OBS:
1. Já atualizei o drive, e mudei o cabo.
2. Eu usava um notebook antes deste com Intel® Graphics Media Accelerator 4500M e funcionava perfeitamente.
Agradecido.
0 件の賞賛
5 返答(返信)
DArce
高評価コントリビューター III
2,877件の閲覧回数
Just to make sure, you refer that the image on the monitor flickers?
Could you please provide the model of the external monitor/TV displays you tested with?
Are you using any type of adapter or converter in between the monitor and the VGA port in your system?
Are you seeing this issue when you boot the system to the system BIOS or when you boot to the operating system on safe mode?
ABrit4
ビギナー
2,877件の閲覧回数
Olá Diego
Respondendo
1. Correto, a imagem no monitor treme!
2. Monitor LG FLATRON E2241
3. Não estou usando adaptador, somente o cabo VGA.
4. Não vejo nenhum problema na iniciação do sistema.
Muito obrigado Diego.
DArce
高評価コントリビューター III
2,877件の閲覧回数
And have you tried adjusting the refresh rate on the video properties? Or tried using a different video resolution?
information on where to check that setting is available here:
http://www.intel.com/support/graphics/sb/cs-009488.htm Graphics | How To Verify Resolution, Colors, And Refresh Rate
What is the native video resolution for the monitor you have connected?
Please post the diagnostic report generated by the video controller. The following article explains how to get this informational report:
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics | Intel(R) Graphics Driver Report
ABrit4
ビギナー
2,877件の閲覧回数
Olá Diego,
A resolução padrão do monitor de acordo com o site da LG é de 1920 x 1080, fiz algumas modificações nas propriedades de vídeo, modifiquei a resolução para 1680 x 1050 e também a taxa de atualização para 59p Hz e reparei melhorias exemplo " a imagem do monitor não treme mas". Em compensação vejo diferença nos textos como segue na imagem em anexo. Veja que, em uma linha e outra a diferença de visibilidade.
Segue o relatório
Intel(R) HD Graphics 4000
Report Date: 7/22/2013
Report Time[hh:mm:ss]: 00:32:56
Driver Version: 9.18.10.3165
Operating System: Windows 8 (6.2.9200)
Default Language: Portuguese (Brazil)
Installed DirectX* Version: 11.1
Supported DirectX* Version: 11.1
Shader Version: 5.0
OpenGL* Version: 0.0
Physical Memory: 8069 MB
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Processor Speed: 2295 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Graphics Mode: 1680 by 1050
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Non Active Notebook Displays: 1
* Monitor *
Monitor Name: Monitor Genérico PnP
Display Type: Analog
Connector Type: VGA
Serial Number: GSM5818
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 18,90 inches
Vertical: 10,63 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1280 by 1024 (75 Hz)
1280 by 1024 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D 18 58 01 01 01 01
0A 16 01 03 6C 30 1B 78 EA 95 35 A1 59 57 9F 27
0E 50 54 A5 4B 00 71 4F 81 80 81 8F B3 00 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 DD 0C 11 00 00 1E 00 00 00 FD 00 38 4B 1E
53 0F 00 0A 20 20 20 20 20 20 00 00 00 FC 00 45
32 32 34 31 0A 20 20 20 20 20 20 20 00 00 00 FF
00 53 65 72 69 61 6C 4E 75 6D 62 65 72 0A 00 60
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Connector Type: LVDS
Serial Number: LGD02F8
Gamma Value: 2,2
Maximum Image Size:
Horizontal: 12,20 inches
Vertical: 06,69 inches
1366 by 768 (60 Hz)
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
* Other names and brands are the property of their respective owners. *
DArce
高評価コントリビューター III
2,877件の閲覧回数
Have you tried using the latest monitor driver provided by LG?
Did you test using the latest video driver provided by your laptop manufacturer? Did you also update the system BIOS?
Did you see the screen flicker when testing for example 1920 by 1080 (60 Hz) or 1680 by 1050 (60 Hz) or 1024 by 768 (60 Hz)? Please test with all these three.
返信
