23054 Discussions
Problemas al tratar de actualizar Controlador de Graficos Intel UHD Grapics 620 - 26.20.100.7925
cartaf7
al tratar de actualizar Controlador de Gráficos Intel UHD Grapics 620, tengo una notificación de que "Algo fue mal" El sistema tiene un controlador que esta bloqueando según las especificaciones del fabricante.
Senkuchan
Valued Contributor II
The error message indicates that your OEM is preventing you from updating the graphics with a generic driver. Since you have an OEM system, such as dell, acer, asus, hp, etc, it is recommended that you download the driver from their website, as it is tailored for your system. However, you can also choose to use the generic driver from the intel website. For more information and troubleshooting steps, please refer to these links:
https://www.intel.com/content/www/us/en/support/articles/000056629/graphics.html
https://www.intel.com/content/www/us/en/support/articles/000005469/graphics.html
Senkuchan
RamyerM_Intel
Tenga en cuenta que solo podemos brindarle asistencia en inglés. Hemos utilizado una herramienta de traducción web para traducir esta respuesta, por lo tanto, puede haber alguna traducción inexacta.
I can see that you are having issues with the Intel Arc Control software. To better understand the situation, please share the following detailsL
  1. What driver version are you trying to install?
  2. Are you installing it using Intel Driver and support Assistant?
  3. Are you experiencing other display issues?
  4. Were you able to use the software before?
  5. Have you made any changes before the issue occurred? If you do, kindly please indicate if it is a software or a hardware change.
  6. Please share the .txt file from this link: https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
  7. Have you tried any troubleshooting steps?
Ramyer M.
RamyerM_Intel
Hello cartaf7,
I agree with the resolution provided by Senkuchan. This is the correct answer for OEM devices. However, if you still face any issues, please respond to this thread with the answers to my questions. I will be happy to assist you further..
Ramyer M.
RamyerM_Intel
Hello cartaf7,
I noticed that we have not heard a response from you. As such, we will proceed in closing this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Ramyer M.
