23787 Discussions
Problemas con 144hz
youcanyoucan
Hola, tengo un monitor de 144hz. Más específico LG 24GL600F.
Mi procesador es intel i5 9400 con los gráficos integrados UHD 630.
Compre HDMI 2.1 de muy buena calidad para colocarlo a 144hz pero solo llega a 120hz
¿Alguna solución? ya actualice los controladores de gráficos, etcétera
Senkuchan
Valued Contributor II
Try updating your graphics driver. Here’s the link: https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html
However, what is the make and model of your computer? Because we need to check if the the video port you’re using can get a higher refresh rate
MUC
Honored Contributor I
The LG UltraGear 24GL600F monitor has two HDMI ports of version 1.4 and one DisplayPort 1.2 connector.
To squeeze 1080p @ 144 Hz into the bandwidth of HDMI 1.4, LG uses a non-standard video timing. The parameters marked in yellow deviate from Coordinated Video Timing - Reduced Blanking (CVT-RB).
If your device with UHD630 does not allow this via HDMI, your only option is to connect the monitor via DisplayPort (without an adapter). If the device only features an HDMI output and is an OEM device (e.g. a laptop), you can only try to see if the graphics driver provided by the OEM leads to a solution.
RonaldM_Intel
Hi @youcanyoucan
The information provided by @MUC is accurate and explains why the 144hz is not showing up for you.
Have you checked the recommendation to test via DisplayPort?  You can also try the driver supplied by your laptop manufacturer just in case.
Ronald M.
