23526 Discussions
Problems with Driver Version: 15.40.28.64.4501
aandr28
Hi guys, i have laptop powered with intel I7 6700HQ Intel HD 530 Graphics, manufacturer HP. Currently im using Driver Version: 15.40.26.64.4474 drivers those work good with no problems and hundred times better then HP modified drivers.
Today by update tool i was offered to update drivers to Driver Version: 15.40.28.64.4501. After update graphics control panel gone no able to use it, settings messed up in windows display settings. tried to reinstall several times, tried to delete old drivers with software
and to do clean driver install , all the time getting the same problems. Going back to Driver Version: 15.40.26.64.4474 pc works fine as should. Machine runs win 10 pro 1067.
Regards.
aandr28
i want to update my thread, today i have downloaded and installed the newest beta drivers version 15.40.4539Beta and they work perfect as i can see form the first view all problems i had with 5401 version are eliminated, but faced other problem drivers are not digitally signed with Microsoft. Guys it would be much appreciated if you could fix it. Thanks. As i don't want each restart of my PC switch off forced Microsoft digital sign up of drivers.
aandr28
any news on driver problem?
Loeschzwerg
It's an unofficial driver, but worth a try:
http://forums.laptopvideo2go.com/topic/31656-2120164506-1545xx-7th-and-6th-generation-kabylake-broxton-apollo-lake-and-skylake-windows-10-windows-81-windows-8-windows-7/ 21.20.16.4506 (15.45.xx) - 7th and 6th generation (Kabylake, Broxton (Apollo Lake) and Skylake), Windows 10 / Windows 8.…
Hellen_D_Intel
Hi Lucanas,
The information is still under review. I'll be posting as soon as I get any answer.
Hellen.
Loeschzwerg
lucanas Here a link to v4509 => http://www.station-drivers.com/index.php?option=com_remository&Itemid=352&func=fileinfo&id=2455&lang=en Intel HD & Iris Graphics Drivers Version 15.40.29.64.4509 WHQL
Maybe it helps.
aandr28
any news ? as a few weeks gone with the last reply, we are still waiting for fix.
aandr28
Thanks for the try to help mate but with these drivers the same problem we are suffering from 4501 package
aandr28
so at the end of all my research, thanks to one of replies with the link to other drivers i got installed version 21.20.16.4526 and it seems to work fine and they are much newer i had before. At the moment seems to be no problems but going to do some tests.
aandr28
ok got to go back to older drivers again as drivers taken form windows update didn't work very well 21.20.16.4526 with them i got some strange heat issues, cpu heated more while gaming and no performance increase over older version. So still waiting reply then 501 version is going to be fixed or new drivers released.
Loeschzwerg
Have you tried the latest Beta v4530?
aandr28
yes I did exactly the same problem, and its 100% problem within the driver as if I use driver designed for intel iris as 21.20.16.4526 (cab from Microsoft wu) it installs and works nearly perfect giving minor problems but this proves that the problem is with drivers and only Intel HD graphics is effected, intel Iris works fine.
aandr28
i tied it again, disconnected second screen, restarted pc, then installed from configuration file v4350 as new device, and got some interesting problems I will upload two pictures those show problem is with driver signature within Microsoft and even drivers are installed the Microsoft basic graphics divers are working only. I have tried all possible driver install ways, every time the same. I have switched off driver digital signup at start up to eliminate problem in the pictures I have uploaded then I got problems mentioned why this thread was created. I think v4501 was modified to version v4530 with no fix to our real problems it was just modified to get better experience to play specific game.
aandr28
Thank you for sharing this information. I am glad to hear driver version 4539 fixes this issue.
To answer your question, please bear in mind that you are loading a beta driver that has not been validated and certified yet.
Please see the attachment for more information.
Allan.
aandr28
I understand that to certify and sign digitally with Microsoft cost big money and I understand beta meaning, as these beta drivers works perfect and they work perfect fro the moment I have installed and has improvement in 3D graphics as gaming an so on , I hope driver developers will be able quicker to release stable certified driver.
