23806 Discussions
Problems with Intel® UHD Graphics 750
Percysr
I just bought this processador i7-11700 , all is ok but when it displays a QR code or when I am using a form or excel, has problems for show it. when I uninstall it all is ok, you know what is the problem?
Example: Whatsapp, you see code it is not correct:
RonaldM_Intel
Hello @Percysr ,
We just released a new Beta driver version 27.20.100.9616 that you're welcome to try. I'm not 100% sure the code change that is confirmed to fix this issue is included in this Beta, but it is possible it slip into this one as well, so give it a shot and let us know your feedback.
I would like to confirm the Production driver that is confirmed to have the fix for this issue is still targeting mid-June 2021 release.
Ronald M.
DeividA_Intel
Hello Percys,
I would like to let you know that we are working on releasing a new driver to fix the issue, just keep an eye on the Downloadcenter.intel.com to get the latest driver.
For the moment, I recommend you to disable the Hardware Acceleration (if possible) and access the following thread where you will find details about this issue.
- https://community.intel.com/t5/Graphics/Iris-Xe-and-AWS-Workspaces/m-p/1281134/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtPTVdWNVZQVldaVTNUfDEyODExMzR8U1VCU0NSSVBUSU9OU3xoSw#M97020
Deivid A.
RonaldM_Intel
Hello @Percysr ,
Ronald M.
Percysr
Thank you very much! i just install the driver and it is FIXED!.
whatsapp code it is  ok:
thanks a lot
