23280 Discussions
adding a third monitor
tiagonava
System information:
DELL™ OPTIPLEX™ 9010
Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz 3.30 GHz
Intel(R) DH Graphics Familly 2500
Windows 10
Monitors 2x Dell P2317H, connected to the DisplayPort and working properly
Questions: I would like to add a third monitor to the VGA port (the only one still available), but it does not work. Interestingly, it is recognized by the Windows and I can even see it when I personalize the monitors, however, I only get to make it work two by two. On the other hand, when I open the Intel graphical parameters, the analogic connection simply does not appear. For information, the third monitor is an old Dell P107s but I have already tried with others and the problem is the same. Thanks in advance for your help.
AlHill
There is no Intel driver for Windows 10 for your graphics.   All you have is the Microsoft generic driver, which lacks features and performance.
Time to consider upgrading to a new(er) platform.
tiagonava
Thanks, AlHill! What would you suggest? A new graphic card or an entirely new equipment?
AlHill
Either, but new equipment will serve you for the future.  It may not be long before Microsoft desides to not support 3rd gen platforms.
If a graphic card, try to go with an older nvidia card, a 750 or 1050 (or something in that area).
