23102 Discussions
Problems with the G41 Chipset and a Sceptre Monitor
I just got a Lenovo H410 77241AU running Windows 7 Home Premium with a Intel G41 Express Chipset and am having problems getting the screen to display well on my Sceptre E230BD-FHD 23" LED TV / Monitor. The G41 does not recognize the Scepter and is treating it as a generic non-plug-and-play monitor.
When I connect them HDMI-to-HDMI, it shows up in 1920x1080 resolution but the fonts are all pixelated and hard to read. I can change the screen settings to the non-native display of 1600x900 and that works, but still leaves everything fuzzy.
When I connect them VGA-to-VGA, the screen displays in 1920x1080, but is compressed horizontally and not using the whole screen. About 20% of the left-hand side of the screen is black and the computer's display is squeezed into the remaining 80% (it is not going over the edge of the screen on the right as I can still see the clock at the bottom right of the taskbar).
I've updated the drivers for the Intel G41, but still have these problem. As far as I can tell, Sceptre has not put out a driver or EDID for that monitor for Windows 7. Does anyone have any suggestions?
Lenovo H410 PC Specs:
http://outlet.lenovo.com/desktops/ideacentre/7724xf1.html http://outlet.lenovo.com/desktops/ideacentre/7724xf1.html
SCEPTRE Monitor Specs:
http://www.sceptre.com/Products/LEDTV/Specs/E230BD-FHD%20MainPage.htm http://www.sceptre.com/Products/LEDTV/Specs/E230BD-FHD%20MainPage.htm
DArce
Valued Contributor III
I suggest you to review and complete the troubleshooting steps in the wizard guide here:
http://support.intel.com/support/graphics/sb/CS-022544.htm http://support.intel.com/support/graphics/sb/CS-022544.htm
If the issue persists, visit the following URL and use the driver posted there for your controller:
http://www.intel.com/support/graphics/sb/CS-028366.htm http://www.intel.com/support/graphics/sb/CS-028366.htm
Be sure to install the inf monitor drivers for the monitor connected and update your system BIOS too.
DArce
Thanks. The driver you directed me to did solve the problem.
I had seen the Intel info about that driver previously, but didn't try it out as I thought that it was addressing a different problem. The description for that driver referred to it as a solution for when resolutions like 1920x1080 weren't showing up in graphics properties. In my case, 1920x1080 was being listed as a choice, but it wasn't displaying properly when it was selected.
Regardless, I have now intalled that driver and the display is working correctly in 1920x1080, so thanks!
DArce
You are welcome. I am glad to know that you have been able to correct this problem.
