23096 Discussions
Profile can not be saved
When I try to save a profile crashes my graphics control panel.
Sometimes a errormessage came "Das Profil kann nicht gespeichert werden, Ein Systemfehler ist aufgetreten".
Intel(R) HD Graphics 520
Report Date: Tuesday, December 20, 2016
Report Time [hh:mm:ss]: 7:06:58 PM
Driver Version: 21.20.16.4542
Operating System: Windows* 10 Pro (10.0.14393)
Physical Memory: 8110 MB
Vendor ID: 8086
Device ID: 1916
Device Revision: 07
Graphics Output Protocol (GOP) Version: 9.0.1042
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
Processor Speed: 2592 MHz
Processor Graphics in Use: Intel(R) HD Graphics 520
Shader Version: 5.1
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 7.48 inches
Supported Modes
1920 x 1080 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 A7 04 00 00 00 00
00 19 01 04 95 22 13 78 EA A1 C5 94 59 57 8F 27
20 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 2E 36 80 A0 70 38 1F 40 30 20
35 00 58 C2 10 00 00 1A 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 35 36 57 46 36 2D 53 50 4B 31 00 4F
* Other names and brands are the property of their respective owners.
Hello fasj2001
I will be more than glad to assist you with your matter.
Before I can provide you further assistance, could you please provide me with the following information:
Could you please send the screenshots of the issue that you are seeing?
Could you please confirm the model of your laptop or desktop motherboard?
Hope I can hear from you soon.
Angie
Hope this helps.
Hello fasj2001,
Thank you for the reply.
I will continue with the investigation about your matter.
As soon as I have further details I will let you know.
Angie
i found some more information.
with the local admin it works well, but with my daily user (mailto:xxx@outlook.com xxx@outlook.com) the Problems still there.
I have 2 HDD´s in the Laptop.
The local admin is at c:
My User is at d:
Hello fasj2001,
By any chance, have you checked if there is any incompatibility with both users, and maybe one does not allow, or give the rights to the other user when you try to do the modification?
Please let me know your findings. All the information it is really appreciated.
Angie
both user have admin rights.
i install the software with this user.
Hello fasj2001,
Thanks for your faster response.
Could you please confirm the model of your laptop?
This will be the last detail in order to continue with the investigation.
Your time and response is really appreciated.
Angie
Hallo,
It is a Medion Akoya P6659 (MD 99869)
Here the link.:
http://www.medion.com/de/shop/multimedia-notebooks-medion-akoya-p6659-md-99869-30020345a1.html?searchTerm=30020345 MEDION® AKOYA® P6659 (MD 99869)
Hello fasj2001,
I do apologize for the delay on my reply.
After an extensive research with the information of your laptop (Medion Akoya P6659 (MD 99869)), I was looking for the drivers of your manufacturer(OEM) and I was unable to find on their website.
In the meantime, you can try to test a manual install of the latest Intel generic driver for your laptop.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88355 Intel® Graphics Driver [15.45] (Version: 15.45.10.4542 (Latest) Date: 11/9/2016)
Also, please bear in mind, Intel recommends you to install at first the drivers provided by the manufacturer(OEM) of your equipment.
The OEM drivers are created to be compatible with all the settings, and the set of instruction of your computer (More specific, Chipset). They are specially designed to avoid any issue with your system and improve its performance.
Please let me know how it goes the test, in order to further assist you if required.
Angie
Hello fasj2001,
I would like to know if the information provided to you was able to solve your concern?
In case if you need further assistance do not hesitate to reply back.
I am looking forward to hearing from you.
Angie.
Sorry it doesn´t help.
I try it three times......
Hello fasj2001,
I am really sorry to hear that your issue persists,
At this moment, since our generic drivers did not solve your issue. My recommendation is to contact directly the manufacturer(OEM) of your product.
At the following link, you will be able to get technical assistance from Medion, in regard to your concern:
https://www.medion.com/gb/service/start/ Medion Technical Support
Angie
I found the Soulution by myself.
I found at my Lenovo thinkpad the *.igp Files and search it on my Medion Laptop.
The Dictionary User\name\IntelGraphicsProfiles is missing and needs full rights by the user.
Hi fasj2001,
I am glad to know that you were able to solve the issue.
Thank you for sharing the information, it will be helpful for other peers in the forum.
Please let me know if you need further assistance.
Juan Carlos
