23270 Discussions
Qt-based applications working with OpenGL were broken after driver update
ginte
Hello!
After the Intel Graphics 630 driver was updated Qt-based applications
working with OpenGL were broken altogether.
Tha last working version is 15.45.16.4627.
Versions 15.45.18.4664 and 15.45.19.4678 are broken.
To reproduce the bug one can use the attached sample (actually diff/patch for the oficial sample from Qt). The sample
is from the official Qt's collection of examples but with a slight
change: it contains QOpenGLWidget. Microsoft Visual Studio 2015
with latest update is required to build the sample (Qt also must be
built with the same version of the compiler; it can be downloaded
from the oficial site qt.io).
However if the backends software/angle are used the application
works correctly and its GUI is not distorted.
The bug is reproducibale with Qt version 5.7.0, 5.8.0 and the lastest
5.9.0.
Also if a dock-widget with OGL-context is detached from the main
window or closed then the interface "partly" restores: I mean "partly"
because it will be better but not correct as it should be.
Screenshots attached:
1. dockwidgets_QT5.9---no-openglwidget.png - main window with no opengl-widget child;
2. dockwidgets_QT5.9---openglwidget.png - openglwidget shown. Notice that the font is not clear anymore; icons/toolbar shifted/cut; also right side of the widgets cut.
3. dockwidgets_QT5.9---detached_openglwidget - openglwidget was detached from the main window (application was not restarted).
ginte
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel Core i7 7700K with integrated HD Graphics 630
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No, there is only integrated video.
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP
How much memory [RAM] in the system (see note2 below).
32GiB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
HDMI cable, DVI-D <-> HDMI cable (two monitors are connected)
Hardware Stepping (see note1 below).
<td rowspan="4" style="border: 0px solid black; padding: 0 5.4pt 0 5.4pt; border-right: solid windowtext 1.0pt; border-bottom: solid black 1.0pt; border-left: solid windowtext 1.0pt; border-top: none;" ...
gshep_amd: Thank you very much for joining the Intel® Graphics communities.
In order to try to find a possible solution to fix this problem, we will do further research on this matter. As soon as I get any updates, I will post all the details on this thread.
Any further questions, please let me know.
Alberto R
gshep_amd: I just received an update, please install the following driver and let us know the results, version 4729:
https://downloadcenter.intel.com/download/26941 https://downloadcenter.intel.com/download/26941
Alberto R
gshep_amd: I just wanted to check if you were able to install the driver provided previously and if you need further assistance on this matter?
Alberto R
ginte
Hello!
First of all I am sorry for the late response. When you posted your
answer I was going on my vacation.
Our QA-team confirmed that the last version of drivers solves the issue.
Thanks a lot for your assistance!
gshep_amd: You are very welcome. No problem at all, it is great to hear that the problem got fixed after installing driver version: 4729.
Any other inquiry, do not hesitate in contact us again.
Alberto R
BDesa2
Hi
I exactly have the same problem , and downloading the installing the drivers did not help .
I have explained the problem on the QT forum.
https://bugreports.qt.io/browse/QTBUG-63508 [QTBUG-63508] QL QML Designer blurry and Mouse click on designer misplaced - Qt Bug Tracker
Could you tell me how did you solve this issue.
Hi Prasad1985: Please submit your inquiry on a new thread, the reason for this is that every scenario is different even if the same product is being used, so for us to better assist you and in order to try to fix the problem, please submit a new thread:
/community/tech https://communities.intel.com/community/tech
Let me apologize for any inconvenience.
Alberto R
BDesa2
Hi Alberto
Yes I shall do it as soon as possible.
Prasad
Hi Prasad1985: Perfect, thank you very much.
Alberto R
