Hi guys
I attach here verilog code for a module which beside some other stuff, grab external carrier detect signal from modem and this signal retimed is also intended to drive an output port for led purpose. Quartus seems consider dangling port and ties it to gnd. Can i avoud this situation?
Thanks in advance!
BR
Hello Armando1989,
- What is the Intel product that you are inquiring?
- Can you further elaborate the issue that you encounter?
- Was it working fine before?
- Did you change any settings before the issue started?
Michael L.
Topic Options
