- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I'm considering a laptop with integrated Arc Graphic to use AutoCAD.
However, I see this announcement about "retain mode" issue with AutoCAD for integrated Arc Pro Graphic: https://www.intel.com/content/www/us/en/support/articles/000100057/graphics.html
Since Arc Graphic or older Intel integrated graphics also use dynamic memory, I wonder if I would have the same issue when using integrated Arc Graphic for AutoCAD
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Khanh275,
To better understand your query and offer an effective answer or recommendation, please provide the following key information:
- Could you let me know which version of AutoCAD you plan to use on a laptop with integrated Arc Graphics?
- Do you have a specific laptop make/model in mind so I can review its specifications first?
JeanetteC.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thank you for looking into this.
I plan to use AutoCAD 2024.
For laptop, I plan to use this one with Ultra 5 125H
https://psref.lenovo.com/Product/IdeaPad/IdeaPad_Slim_5_14IMH9?tab=spec
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Khanh275,
Thank you for providing the necessary information that my Colleague, @JeannetteC_Intel was requesting. I will need more time to further look into your query. I will get back to you once available information is available.
Robbie R.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Khanh275,
Thank you for patiently waiting. To answer your questions, please refer to the information provided below:
The "retain mode" function error remains a known issue, and the Autodesk AutoCAD development team is working to resolve this defect. However, a fix will not be made available by Autodesk for the 2025 and prior versions. Further information will be added to this support page when a fix is available by Autodesk, which means that the 2024 version will also encounter the retain mode function error.
Since you plan to use the integrated graphics of the processor, Autodesk AutoCAD 2024 currently recognizes the graphic capabilities differently to a discrete GPU and only sees 0 MBs or 128 MBs of memory. Despite the limitation posed by the error, the same functionality is experienced as previous-generation integrated graphics solutions.
With that in mind, kindly contact Autodesk for more suggestions and possible configurations on the system that you plan to use.
As such, please be advised that this thread will no longer be monitored. Kindly post a new thread if you have other questions.
Robbie R.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
