23538 Discussions
Quick Sync Video H.264 Encoder MFT resource leak
Freud
issue:
resource leaks  when stopped.
It's normal on amd and nvidia gpu。
cpu: i5 8400 / i9 9900
gpu: Intel® UHD Graphics 630
OS: win 10 / 11
driver:  27.20.100.9616 / 30.0.101.3113  / 31.0.101.2111 (Latest)
code:  https://gist.github.com/KeloCube/0e56ba7f2c5729223483147eb35d9cc7
Jean_Intel
Hello Freud,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello Freud,
  • What type of resource leak did you find? Is it a memory leak?
  • Provide me with the steps to replicate the issue.
  • Create a report using the Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • • Click on the menu where it says: "Summary" to change it to "Detailed View."
    • • To save your scan: click on "Next"; then "Save."
Jean O.
Freud
Jean_Intel
Hello Freud,
Jean O.
Jean_Intel
Hello Freud,
Jean O.
Jean_Intel
Hello Freud,
To continue with my investigation, I would like to confirm the following information:
  • What are you exactly creating?
  • Can you provide a sample and step-by-step how and where to run the app?
  • Can you share a video showing up the issue?
  • Are you creating this application for work? What is your company name?
  • Can you test if the same happens on the 11th or 12th gen Intel processor?
  • How are you checking or detecting the memory leak?
Jean O.
Jean_Intel
Hello Freud,
Jean O.
Jean_Intel
Hello Freud,
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
