22777 Discussions
QuickSync H.264 FFMPEG 5.0 bitrate rate ignored since driver update
poptravel
I am running a scripted ffmpeg transcode scripts for weeks that fail to work properly since a driver update.
Since the driver Update of Intel UHD to 30.0.101.1340 the bitrate argument is being ignored. I'm pretty sure this is a Intel driver problem as the same ffmpeg version was working before honoring the "-b:v 37.5M" argument for 37.5 Mbit/s while now it is going between 60-100 Mbit/s.
How can the driver be rolled back or can this issue get confirmed?
David_G_Intel
Hello poptravel
Thank you for posting on the Intel️® communities. Please share with us the following information to investigate:
  • Did this start with the .1340 driver?
  • Did you try other drivers?
  • Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
