23105 Discussions
Raid 5 on X58 / ICH10R need help
motherboard: asus Rampage III Extremechipset: intel X58 / ICH10RStorage: Marvell® 9128 PCIe SATA 6Gb/s controller 2 xSATA 6.0 Gb/s ports Intel ICH10R controller 6 xSATA 3.0 Gb/s ports 0,1,5,10 Intel Matrix Storage Technology Support RAID SATA 3.0 Gb/s port 1 x External SATA 3.0 Gb/s port (SATA On-the-Go) 1 x JMicron® JMB363 PATA and SATA controller driver Intel(R) ICH8R/ICH9R/ICH10R/DO/PCH SATA RAID Controller version 8.9.0.1023 (x64)OS Windows Server 2008 R2 Raid 5 is built from 3 discsonce a week fails the second or third party diskphysical disks are OK, no bad blocks, drives under warranty, electronics okay.We have to mark the drive as a normal party, the array is rebuilt. a week later the situation is repeated. What should I do? What's the problem? on the same controller is a raid 0 array of two drives - the system no problems. All harddrives are the same.
No, not installed
What makes this utility?
I installed it
Driver has been updated
but the application does not run. intel rst service not working
service is not installed. Installation done via RDP - can influence?
Can you see that the driver has been updated in device manager under "storage controllers" that should list "Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller" with driver tab showing 10.1.0.1008 ?
You may have to do this:
/message/116743# 116743 http://communities.intel.com/message/116743# 116743
