23526 Discussions
Red tint on the screen Intel UHD graphics
skrullh
My laptop Lenovo IdeaPad 3 15-IML05:
Windows 10 Pro x64
CPU: Intel Core I5-10210U
UMA GPU: Intel UHD 620
GPU: Nvidia GeForce MX 130
RAM: 8Gb DDR4
SSD: SKHynix_HFM512GHTNI-87A0B
After I repaired BSODs, caused by fault stick of RAM I turned it off and next time I booted, after loggining to windows my screen tinted red.
When I forcibly turn off  Intel integrated GPU and use only a discrete chip(Nvidia GeForce MX 130), everything is fine.
Could the processor fail?? (I turned on the device without a cooling system to check the overall performance during the previous repair)
what could be causing this error?
Jean_Intel
Hello skrullh,
Thanks for posting in the Intel Communities. We understand that you are experiencing graphical issues with your system, we will do our best to help you and find a solution to your problem.
Sometimes, corrupted files from the previous driver versions can cause system malfunctions and can cause driver updates to not work as expected. Perform a clean installation, installing the latest driver version available for your unit on the Lenovo Website, driver 30.0.100.9864. It is important to add that there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM).
Jean O.
Jean_Intel
Hello skrullh,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello skrullh,
We have not heard back from you. So we will close this thread. If you need additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
