23832 Discussions
Reduce memory to HD Graphics 530
MPino1
In a 32 bit system, Graphics 530 use 2 Gb. Its possible to reduce it? .
MPino1
To complete the question:
I have a Dell Vostro with intel Core i3 6100, 4 Gb system RAM. For compatibility with an application I must use Windows 7 32 bits. By default Graphics 530 use 2 Gb, allow another 2 Gb for system. Its possible to configure 1 Gb for Graphics and 3 Gb for system?
Thanks in advance
MPino1
I´m sorry. I was confused. Video memory is 1 Gb.
BNels3
Why would you want to make it use less? And have you tried Google?
I found this: https://www.computing.net/answers/hardware/how-do-i-set-memory-for-intel-hd-graphics/74833.html [Solved] How do I set memory for intel HD graphics? Have a look at it.
MPino1
I want to make it use less to leave more memory for system. No need video memory. Yes, I use google.
Hello mariormb,
Thank you for contacting the Intel community.
This depends on your system manufacturer BIOS, the BIOS can set to less or more memory for the graphics.
Good to know that you double check and there is 1GB instead of 2GB.
Best wishes,
Ivan.
MPino1
Thank you Ivan,
Anyway I don´t know where is the missing Gb. In older machines (whenever 32 bits), with 4 Gb, video memory occupied 1 Gb and 3.xx Gb for system. Today with this newest machine (Vostro 3650), i3-6100 SKL-S, 1 Gb for video memory and 2,09 Gb for system. Where is the other Gb?
I can not change nothing in BIOS related with memory.
In this case, the best place for obtaining information about your computer's specific configuration is from your computer manufacturer. Your computer manufacturer may have altered features, incorporated customizations, or made other changes that may limit or reduce the actual maximum graphics memory amount possible for your computer.
You can check in your BIOS what the amount of memory installed is but this depends as well of your computer manufacturer if this option is available or not.
Ivan.
