21079 Discussions
The Chronicles of Riddick: Assault on Dark Athena screen flickering
Parapele
Hello everyone! I guess, i can tracking one more.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
white screen flickering
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): x
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
custom GIGABYTE H110M-S2H i3-6100
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
only HD 530
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
SAMSUNG SyncMaster 204B
How much memory [RAM] in the system (see note2 below).
8Gb DDR4 2133
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
Hardware Stepping (see note1 below).
<td rowspan="4" style="border: 0px solid black; padding: 0 5.4pt 0 5.4pt; border-right: solid windowtext 1.0pt; border-bottom: solid black 1.0pt; border-left: solid windowtext 1.0pt; border-top: no...
Hello Parapele,
Thank you for contacting the Intel community.
Try http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html uninstalling the graphics driver and reinstall it manually, please check how to http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
Do you have the latest BIOS version and Windows up to date to the latest Windows 10 Anniversary Update?
How do you have the computer connected to the monitor? Is it connected via HDMI from the computer to the monitor or are you using DisplayPort?
Are you using any adapters? If you are using HDMI, can you try different HDMI cable, high quality cable if it is possible if not that is understandable.
Please let me know.
Ivan.
Parapele
Facepalm... Okay, you don't recognise me. I'M that dude who writes on broken english, who made decision reporting about bugs always when i see bug, and who made already /message/454851 https://communities.intel.com/message/454851 , /message/456453 https://communities.intel.com/message/456453 , /thread/111898 https://communities.intel.com/thread/111898 , /message/458177 https://communities.intel.com/message/458177 , retest /thread/110092 https://communities.intel.com/thread/110092 , and finally this report.
My Intel driver collection in zip 1.8GB, and more 4GB when extracted. Can you count how many times i uninstall and reinstall driver?
No, for GIGABYTE H110M-S2H i dont have last BIOS, now it F4, next BIOS is F20 (Support 7th generation CPU * This BIOS prohibits updating to earlier version BIOS) support Kaby Lake not will fix your driver bug, no i not gonna make update.
Windows update disabled, last Anniversary Update cause for me problem. I need PC as working machine, Microsoft not will control when my pc work or not, i dot need surprises. I will make clean install Redstone 3 update.
HDMI? DisplayPort? VGA. "if you set 8 bit bug disappears" you even don't read, don't you?
Guys, please stop answering like that, if you don't want take care about bug report.
I'm sorry; I have seen may different treads in one day that I lose track of the people I talk to. Your message has been read and understood very well, the reason why I suggest uninstalling and reinstalling the driver is because I did not realize that I have been through this process with you in another threads.
I will further investigate on this issue as well, we appreciate you have taking your valuable time to post on the Intel community.
Ivan.
