22845 Discussions
Refresh rate on 4600 changes to unsupported value
GHoug
I have a 4600 chipset used in our product that is attached to an Advantech display. On occasion when the system is rebooted the display does not work. Traced it back to the refresh rate changing to 70 hz which is unsupported for this display.
Has this ever been seen in the field (changing refresh rate) ? The driver is older (9.18.10.3131, 4/22/13) but would like to know if there was a known issue with the driver before I update and hope it is fixed (it is infrequent but a real problem when it occurs).
From limited understanding the display will report its capabilities when queried. If we have not changed the modes would it impact the current settings ?
Is there a place in the registry where we can lock this down (Windows 7).
Thanks !
IUman
Hello GHoughton,
Thank you for joining the Intel communities.
We have not heard this problem before but if someone else has this problem is free to post it here, and also you can download the latest graphics driver from the following link:
https://downloadcenter.intel.com/download/25588/Intel-Graphics-Driver-for-Windows-7-8-1-15-36-28-4332- Download Intel® Graphics Driver for Windows 7/8.1* [15.36.28.4332]
Ivan
