23854 Discussions
Rotate Display with i5-6500 Integrated Graphics
MSaue1
Hi, I want to rotate my second display. I tried to do it under Control for Intel HD-Graphics -> Display -> Settings but I couldn't find it. Here is a picture (in German) where I looked for it: https://imgur.com/a/5ks5D https://imgur.com/a/5ks5D
Hello Max457,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you want to be able to rotate the screen in your secondary display. I do apologize for the inconvenience, but this option was removed from the driver provided directly by Intel®. This feature was removed because at some point it was added as a feature available in the Windows® 10 standard installation.
In Intel® we are aware that this feature was removed from Windows® 10 and we are currently working to add this feature back in future versions of the generic driver provided by Intel®. Our recommendation regarding the driver provided directly by Intel® is to wait for future releases and install them to confirm if the feature is added in any future release.
Another recommendation would be to install the driver provided by the computer or motherboard manufacturer. Some manufacturers will include the option to rotate the screen in their drivers, and you may need to contact the manufacturer to confirm if this feature is available in the driver that they provide with for the system.
Xavier A.
Hello Max457,
I was checking your case and would like to know if you need further assistance. If so, please do not hesitate in replying back.
Xavier A.
