22903 Discussions
Running diagnostic on Windows 7 I receive igdkmd32.sys is causing startup to slow down, when I do a search for the file it can not be found. Looked in search and hidden files. Any idea why this slowdown warning appears when the sys file doesn't exist?
WBarr4
Looking for the cause of slow start up reference from Windows 7 diagnostic?
Amy_C_Intel
Hello, WB32:
Please try uninstalling and re-installing the current Intel® HD Graphics driver version, use this method in order to uninstall;
  1. Open the Device Manager.
  2. Expand the Display Adapters section.
  3. Find the Intel Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
  4. Right click Intel Graphics Driver and select Uninstall.
  5. Select the check box Delete the driver software for this device.
  6. Reboot the computer after uninstall process has finished.
  7. Install the driver using this method http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*. If you don't remember the driver version, let me know your computer model and processor model.
One done, run the diagnostic one more time and let me know if you still receive the warning message.
Amy.
Hello, WB32:
Were you able to follow the suggestion mentioned above?
Amy.
WBarr4
Hi Amy,
The issue seems to be temporary or intermittent since I went into Device Manager and went to the display adapter which identified the
driver as Mobil Intel (R) 945 Express Chipset Family. I checked for any new drivers and it said it's up to date and working. Since my last
e-mail the issue has not come back on the Igdkmd32.sys file that does not exist.
WB32, thank you for reporting this, I am glad to hear that your systems is working.
If you need further assistance let us know.
Amy.
