22821 Discussions
SFF N100 can't output via DP port
Dis93
I just got a Windows 11 Pro N100 mini pc. I can connect it to a HD TV via hdmi and get a signal. I cannot get output from the DP. I have a DP to HDMI cable to my monitor.
If I only have that connected, in device manager I get a display listed with a resolution of 640x480 only.
If I have both connected I only get the TV/Monitor active.
I can use the HDMI to HDMI to the monitor, so the monitor is fine.
I have tried 2 different DP to HDMI cables, one that worked on old PC, the other a brand new DP 1.4 to HDMI cable.
Windows cannot detect a 2nd monitor.
Any advice appreciated.
Caguicla_Intel
Hi Dis93,
To assist you more effectively with the issue you're experiencing, could you please share the manufacturer of your SFF N100? Additionally, if possible, provide a link to the specifications of your unit, which will allow us to review the details thoroughly.
Furthermore, we would appreciate it if you could inform us of the model of your graphics card and the current driver version you are using. This information is crucial for us to understand the situation better and offer a precise solution.
Lastly, does your monitor have a DisplayPort (DP) input? If so, have you tried connecting via a DP to DP cable? This could potentially resolve any display issues you might be facing.
Your cooperation is greatly valued, and we look forward to your response so we can proceed with the necessary troubleshooting steps.
Caguicla C.
Dis93
It's a Dunhoo N100.
The specs are shown in the uploaded images.
It has integrated UHD 800 graphics according to the product page.
My monitor does not have DP input.
I have tried installing the updated grpahics drivers, version 31.0.101.4952
MUC
Honored Contributor I
I have had good experiences with this active protocol converter cable. It is not the cheapest, but it is good:
Club 3D CAC-1087
Dis93
I got a USB-C to HDMI convertor. That works fine.
NormanS_Intel
Hello Dis93,
Thank you for the information you provided. To assist us in delving deeper into the matter, we would be grateful if you could provide the Intel® System Support Utility Logs from your computer. Attaching these logs to this thread will enable us to thoroughly examine your system's configuration.
Additionally, we are curious to know if you have reached out to your computer's manufacturer or place of purchase regarding this issue.
Lastly, if you have access to an alternative monitor equipped with a DisplayPort (DP), we kindly ask you to test it. This will help us determine whether the issue is isolated to the DP port or if it is related to the overall system configuration or setup.
Norman S.
ACarmona_Intel
Hello Dis93,
Again, to assist us in delving deeper into the matter, we would be grateful if you could provide the Intel® System Support Utility Logs from your computer. Attaching these logs to this thread will enable us to thoroughly examine your system's configuration.
Carmona A.
Dis93
Attached is the SSU report.
I don't have a monitor with DP input.
I haven't reached out to the seller, as it was a fulfilled by Amazon purchase.
I haven't reached out to the manufacturer as I can't find a website for them.
ACarmona_Intel
Hello Dis93,
Thank you so much for the response.
Please try the following troubleshooting steps outlined on this link for a possible solution:
If the issue still persists, please let me know, as I will raise the case with our engineers for further investigation.
Carmona A.
ACarmona_Intel
Hello Dis93,
We would like to know if you have any questions regarding the recommendation that we have provided.
If so, kindly inform me, as we would be glad to assist you.
Carmona A.
Dis93
Hi Carmona A.
I tried the suggestions as indicated with no success.
I have given up on the DP connection as the USB-C adapter is working.
Thank you for the assistance.
regards
Dis93
ACarmona_Intel
Hello Dis93,
Thank you so much for the update.
I truly appreciate your efforts in trying to troubleshoot the issue.
Based on the troubleshooting steps that you have taken, it appears that the issue is with your DP port itself. Therefore, we also suggest that you keep in touch with your  system manufacturer  to report this issue, as the other ports are functioning properly.
By the way, since I will no longer be of assistance to you, I will now be closing our case. For additional information, please submit a new question, as this thread will no longer be monitored.
Carmona A.
