23854 Discussions
Saturation Not Showing Up
oweq
Hello there.
I am here to ask a question about why I dont see Hue or Saturation on my intel graphics command center settings. I can show my specs here
and I have a 11th gen Intel i5-11400F 2.6Hz CPU
and I also use a TV as my monitor
PLEASE HELP!
I just want my game to look more colorful
@Jean_Intel sorry I didnt respond on the last post, I was out for a bit. but here is the intel SSU report you wanted me to get you on the last ticket:
Jean_Intel
Hello oweq,
The Hue or Saturation options/features may not be available in the Intel Graphics Command Center. This occurs because the .inf installation file defines that when the XVYCC feature is enabled for that Display the Hue and Saturation features are disabled. XVYCC is automatically detected by the driver if the display connected supports it.
Enabling Hue and Saturation is not necessary since these options/features are mutually exclusive with XVYCC.
Also, you should take into consideration that the F suffix for your processor naming indicates that the CPU has no integrated graphics. I am not sure exactly why your system reports that it has an Iris(R) Xe Graphics. https://www.intel.com/content/www/us/en/support/articles/000027144/processors/intel-core-processors.html
Jean O.
oweq
What do I do then?
Jean_Intel
Hello oweq,
Thanks for your response.
Keep in mind that the XVYCC is enabled on the display and it is automatically detected by the driver if the display connected supports it. Hue and Saturation are mutually exclusive with XVYCC. My recommendation is to contact the display manufacturer for information on how to change these color settings.
Jean O.
Jean_Intel
Hello oweq,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
