23270 Discussions
Scaling settings reverting after disconnecting.
GleebyDeeby
Hello, I have this problem with my second monitor ( I use a small tv), I can change the scaling of the resolution but it always changes back to default settings after disconnecting laptop from the TV. Unfortunately i could not find any settings in the tv set.
I did not have this problem couple of years ago when using older version of Intel Control Panel but the problem occurs now with the newer Intel GCC.
Any ideas on how to solve this problem? I cannot find easily the older version of the program because i guess it was discontinued, also i don't want to downgrade my drivers
GleebyDeeby
Also Alt+Tab reverts the settings of scaling
Jean_Intel
Hello GleebyDeeby
To better assist you, we would like to confirm the following information:
  • Is this issue present since day one?
  • Do the settings go to default after restarting/shutting down the PC?
  • Is there any other graphics control software installed on your system besides the Intel Graphics Command Center?
  • We would like to ask for more system information, please, create a system report using the Intel®️ System Support Utility (Intel®️ SSU):
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
Best regards
Jean O.
GleebyDeeby
1. No this issue wasn't present since day one.
2. Sometimes yes, they do bo back to default settings after a restart.
3. Yes there is nvidia control panel, but i haven't changed there anything.
Jean_Intel
Hello GleebyDeeby,
Thanks for your response.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, maybe fellow community members have the knowledge and will jump in to help you. You may also find the Discontinued Products website, website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued".
Best regards
Jean O.
