When I have the Intel UHD drivers installed on my laptop in Windows 11 it causes my screen to warp and scramble, especially text, making the UI nearly unusable. I attempted removing the drivers in safe mode using DDU and reinstalling them and nothing worked. The only things that consistently work are: uninstalling the drivers and leaving them uninstalled, thus using the windows base adapters, or starting the computer in safe mode. Otherwise it will continue to have problems.
I have also tried:
Changing the resolution and refresh rate on through graphics options
Using the Intel Command Center to turn off panel self refresh (option was not available)
Turning off hardware acceleration on various applications
Hello OnyxFeline,
Thank you for reaching out to the Intel Community Forum.
To help us further investigate the display distortion issue you’re experiencing, could you please provide the following additional details?
- Where did you download the Intel® UHD Graphics driver?
- (For example: Intel Download Center, your system manufacturer’s website, Windows Update, etc.)
- Which graphics driver version(s) have you installed and tested so far?
- Please include the full version number(s), if available.
Additionally, to give us a comprehensive view of your system configuration, we kindly ask that you generate and share a report using the Intel® System Support Utility (SSU). This tool gathers detailed system information that will help us identify potential compatibility or configuration issues.
How to proceed:
- Download and run the Intel® System Support Utility
- Generate the report (default scan settings are fine)
- Save the output as a text file and attach it to your reply
Once we have this information, we’ll be in a better position to continue troubleshooting and provide more targeted recommendations.
We look forward to your response.
Brenz L.
I have tried downloading from Intel, Lenovo (who manufactured my laptop), and from device manager, all have the same issue
Intel: 32.0.101.7085
Windows Fresh Install: 31.0.101.5187 (this was after a system restore, I'm pretty sure it was something different before from windows update but I don't have that number written down)
Lenovo: 32.0.101.6733
Scan attached
Hello OnyxFeline,
Thank you for the detailed information and for sharing the graphics driver versions you have tested.
Before we proceed further, please note that your device is an OEM system manufactured by Lenovo. While we will continue to assist you with general troubleshooting and analysis, some features, behaviors, or limitations may be influenced by OEM‑specific customizations (such as firmware tuning, panel configuration, or BIOS modifications). If the issue persists after general troubleshooting, you may need to contact Lenovo Support, as they are best positioned to address OEM‑level integrations and modifications.
About Intel® Graphics Driver Support Models
For your awareness, Intel has transitioned processor graphics into a legacy software support model based on generation:
10th Generation and Older Intel® Processor Graphics
- As of July 27, 2022, Intel moved 6th–10th Gen Intel® Processor Graphics, along with related Intel Atom®, Pentium®, and Celeron® processor graphics, to legacy support.
- Under this model:
- Only critical fixes and security vulnerabilities are addressed.
- Driver releases occur on a quarterly cadence or as needed.
11th–14th Generation Intel® Processor Graphics
- As of September 19, 2025, Intel moved 11th–14th Gen Intel® Processor Graphics, along with related Intel Atom®, Pentium®, and Celeron® processor graphics, to legacy support.
- Under this model:
- Intel provides updates only for critical fixes and security vulnerabilities.
- Driver updates follow a quarterly release cadence, with additional releases as required.
Please also note that even if a software fix is identified or implemented, such fixes may only be included in Intel® Core™ Ultra Series 1 or newer graphics drivers and may not be back‑ported to drivers applicable to your current graphics hardware.
Would you like to continue with support under these conditions?
Once we have your confirmation, I will proceed to review the information you’ve provided and determine the best possible support path for your case.
We appreciate your understanding and look forward to your response.
Brenz L.
That's fine as long as there is a chance of figuring out what the root of the issue is.
Hello OnyxFeline,
To help us verify and further review the graphics adapter being used for your laptop’s internal display, could you please provide a photo of the display configuration found under Advanced Display Settings?
You can access this by navigating to: Settings → System → Display → Advanced display
Once provided, we’ll be able to review the configuration and assist you further.
Thank you for your cooperation.
Brenz L.
Hello OnyxFeline
Thank you for the reply,
I will do further research on this matter and post the response on this thread once it is available.
Brenz L.
Hello OnyxFeline,
Thank you for your continued cooperation.
After reviewing all the information you’ve provided, I have some initial thoughts on what may be causing the issue. However, to confirm our assessment, may I kindly request a video recording of the reported glitches?
This will allow us to review the behavior in more detail and coordinate further analysis with our internal team.
Look forward to your response.
Brenz L.
Hello OnyxFeline,
Could you please confirm if you have reviewed the information I posted? Your feedback at your earliest convenience would be greatly appreciated so we can decide on the best way to proceed with resolving this matter.
Brenz L.
Hello OnyxFeline,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored. Thank you for understanding.
Brenz L.
