23526 Discussions
Screen goes black during graphics driver install on Windows 8 Pro
CY2
When I tried to install the graphics driver for my i5-4430, the screen went black and I had to use to Windows restore bring it back to normal. The same thing happened when I used the device manager to install the driver. I think I have to use Windows Update to install the driver but then Windows says that "Microsoft Basic Display Adapter" was the latest driver. Do I have to change some settings on Windows Update to make it work?
Here is my system
CPU: http://ark.intel.com/products/75036/Intel-Core-i5-4430-Processor-6M-Cache-up-to-3_20-GHz Intel® Core™ i5-4430 Processor
Graphics: Integrated GPU
HDD: WD Caviar Blue 1TB
Mother Board: Asus B85M-G
Power Supply: Cooler Master GXII 550Watts
RAM: 4GB DDR3 Corsair ValuSelect x2
OS: Windows 8 Pro x64 (64 Bit)
CY2
Is it true that only VGA works after driver install?
Here is my DX diag info.
System Information
Time of this report: 7/31/2013, 14:24:43
Machine name: CHRISPC
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: English (Regional Setting: English)
System Manufacturer: ASUS
System Model: All Series
BIOS: BIOS Date: 06/28/13 21:39:24 Ver: 04.10
Processor: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz (4 CPUs), ~3.0GHz
Memory: 8192MB RAM
Available OS Memory: 7872MB RAM
Page File: 1469MB used, 11011MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Microsoft Basic Display Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) HSW Mobile/Desktop Gra
DAC type: óî
Device Type: Display-Only Device
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_85341043&REV_06
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1920 x 1080 (32 bit) (64Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: Philips 234EL
Monitor Id: PHLC069
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: Internal
Driver Name:
Driver File Version: ()
Driver Version: 6.2.9200.16384
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71AF4-43CC-11CF-B023-F003ADC2CB35}
Vendor ID: 0x1414
Device ID: 0x008C
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: display.inf:10809047d4324726:MSBDA:6.2.9200.16384:pci\cc_0300
Rank Of Driver: 00FB2006
Video Accel:
DXVA2 Modes:
Deinterlace Caps: {00000000-0000-0000-0000-000000000000}: Format(In/Out)=(YUY2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{00000000-0000-0000-0000-000000000000}: Format(In/Out)=(UYVY,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{00000000-0000-0000-0000-000000000000}: Format(In/Out)=(UYVY,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0...
DArce
Valued Contributor III
Please provide additional details on this.
Could you please specify what video ports and cables are you using? What is the model and manufacturer of the displays you tested with?
Is there any adapter or converter being used in between?
What is the versions of the video drivers that you installed in the system?
CY2
I have tried using DVI,HDMI and VGA ports after installing the driver. It seems that when boot the computer up, only the VGA works and the screen is mostly pink. However, when I disable and then enable the graphics on the device manager, the DVI and HDMI ports work fine. The monitors I used were Philips 247E LHA and Philips 234EL. I didn't use and adapter or converter. And my driver version is 9.18.10.3165. I think there is a problem with the driver sequence when it detects for the ports connected. By disabling and enabling, it probably restarts this process and does it correctly. That's what I think is the problem. On a laptop with a core i5 w/ vpro technology, I tried using VGA to extend the display onto a monitor: Philips 234EL and the screen was pink. Anything white was pink and other colors were normal but with a pink shade on it.
DArce
Try removing all the video drivers installed. , this is done through the Control Panel, go to programs and features. Then locate any entry similar to Intel® Graphics Media Accelerator (or Intel(R) HD graphics driver) and remove it. After that, use the Have disk installation instructions on this site to install the latest generic driver we provided:
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
The driver package you need to use is posted here:
https://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/22842/a08/Win64_15319.zip&lang=eng&Dwnldid=22842&DownloadType=%0a%09%09%09%09%09%09%09Drivers%0a%09%09%09%09%09%09&OSFullname=Windows+8%2c+64-bit*
You may also test the latest driver that has been provided by your motherboard manufacturer, which is posted here:
http://www.asus.com/Motherboards/B85MG/# support_Download_36 http://www.asus.com/Motherboards/B85MG/# support_Download_36
