23106 Discussions
Intel HD Graphics: screen shortly blanks, then comes back up
LKerb1
After a few minutes Every 15 minutes the screen will go blank for a few seconds. Then it resumes and works normally again. Audio transmission over HDMI is interrupted too when the blank happens. What's that scary feature? Could it be sleep and do I have to disable it in power management options to prevent that? I must admit I haven't seen power management settings ever influence a graphics driver that way before.
edit: Annoyingly it is re-ocurring. Unfortunately it has become a major annoyance. Please help.
Kevin_M_Intel
Hello foo-on-air,
There are a few questions I would like you to answer for further investigation:
  1. What is the power supply wattage you have?
  2. Is this happening when the system is not in use or when you are using it?
  3. Can you please post your dxdiag report here?
LKerb1
Hi kevin
Appreciate your help.
  1. 300 w. More than enough for a mini itx pc with celeron g1610 + iGPU.
  2. When i am using it and have signal transfer over hdmi ongoing.
  3. Soon.
LKerb1
here comes the lengthy diagnostic report. hope that helps with problem solving.
System Information
Time of this report: 8/13/2013, 13:58:22
Machine name: xxxx
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: German (Regional Setting: German)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 07/12/13 19:27:10 Ver: 04.06.05
Processor: Intel(R) Celeron(R) CPU G1610 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 2048MB RAM
Available OS Memory: 1730MB RAM
Page File: 973MB used, 2487MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RDPDD Chained DD
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: 865 MB
Dedicated Memory: 256 MB
Shared Memory: 609 MB
Current Mode: 1920 x 1200 (32 bit) (60Hz)
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version: 11
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B70EE0-4340-11CF-C468-0A20BEC2C435}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Not Available
D3D Status: Enabled
AGP Status: Not Available
Sound Devices
Description: Remote Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID:
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: {3.0.0.00000001}.{6C26BA7D-F0B2-4225-B422-8168C5261E45}
Driver Version: ()
WHQL Logo'd: No
Date and Size: , 0 bytes
Other Files:
Driver Provider:
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 3/25/2011 05:29:26, 343040 bytes
| Driver: usbd.sys, 3/25/2011 05:28:59, 7936 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 01:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/14/2009 03:48:04, 50768 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x045E, 0x00F0
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 02:00:20, 31232 bytes
| Driver: mouclass.sys, 7/14/2009 03:48:27, 49216 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/21/2010 05:23:47, 63360 bytes
| Driver: sermouse.sys, 7/14/2009 02:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 104.0 GB
Total Space: 127.8 GB
File System: NTFS
Model: ATA WDC WD30EFRX-68A SCSI Disk Device
Drive: 😧
Free Space: 109.1 GB
Total Space: 127.9 GB
File System: NTFS
Model: ATA WDC WD10EADS-00L SCSI Disk Device
Drive: E:
Free ...
Kevin_M_Intel
Hello foo-on-air,
It seems that the dxdiag report has been edited since it is missing some information. Can you please post the complete dxdiag report?
Please, do not delete information about the system information.
LKerb1
just deleted section sound caption devices as it was empty anyways. i edited my post above and pasted the full thing with a heap of returns and empty lines.
