22005 Discussions
Second Screen Disable HD 630/WIN 10-64bit/Intel Core i7
llati1
Hello together,
i am in trouble to set up a new 2nd Screen via HDMI. I cannot connect (indetify on WIN) or at least set up a second screen from my HDMI.
All drivers seem to be up to date or the actual ones, wont fit on my on the system.
Is there any trick, to get fix this problem?
Thank you
Stefan3D
We need some system info.
Upload a report from https://downloadcenter.intel.com/de/download/25293/Intel-System-Support-Utility Intel® System-Support-Utility für Windows * for more help.
Otherwise try drivers from this list https://downloadcenter.intel.com/de/product/98909/Intel-HD-Graphics-630 Downloads für Intel® HD-Grafik 630
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
NB: current drivers for Windows 10 require anniversary update or newer.
