23531 Discussions
Setting color depth manually / internal bug ID 14010239023
stna1981
1,5 years ago, it was held out in prospect that there would be an option in the Intel drivers to manually set the color depth to 10 or 12 bit as the automatic selection of the driver does not always work properly. The release was mentioned for first quartet 2020.
Now we have 2021 and the driver still has no such option. The internal bug ID should be 14010239023. What is the status of that feature? Will it ever be released or is Intel so much focused on the new Xe graphics that there is no support anymore for the "old" (U)HD Graphics?
Best regards
Stefan
David_G_Intel
Hello stna1981
Thank you for posting on the Intel️® communities.  We're working on this request, once we have an update it will be posted on this thread.
David G
Intel Customer Support Technician
David_G_Intel
This Bug ID is still in process, which means the team in charge is still working on this request. We can't provide an ETA but we acknowledge there has been a significant delay in this delivery. Thank you for your patience, we will continue to work on this and it will be available in future updates.
David G
