23838 Discussions
Setting profile for postOOBE sysprep
TF
I am setting up an image for deployment and I need a way to have the profile automatically set so that I don't have to hook up a mouse and keyboard on the machine at time of boot. Is there a way to put a batch file in the startup to accomplish this for me? If so what would that look like?
I am running driver version 9.17.10.2932.
I already have my profile setup the way I want it but I always have to go into the advanced menu and select it.
DArce
Valued Contributor III
There is no hot-key, command line, batch or script or any other similar option for switching display/video profiles in the graphics control panel interface. This needs to be done through opening the graphics option.
TF
Can you tell me what is actually done in the registry? or where it is making it's changes when you physically set the graphics profile?
DArce
I would need to check if this information is publicly available, so let me further investigate on this and get back to you
TF
Thank you for looking into it for me. Please let me know if you find anything.
ROBERT_U_Intel
Hi Tim
Are all the display the same model number? Also, do they all have the same EDID serial number?
TF
Yes, they are being used for a deployment of over 28,000 machines, and they will all be on the same 46 or 42 inch display.
TF
Robert, any update for me?
CMart21
Has there been an update to this option since last post in 2013? I am also looking for a zero-touch deployment method for my computers that have the Intel HD 4000 series graphics controllers installed. I created and exported the profile as instructed by this guide http://www.intel.com/content/www/us/en/support/graphics-drivers/000005857.html How To Use Intel Graphics Profiles for Graphics Drivers. Now I need to be able to set that as the default display profile post image process.
If anyone has any updates that would be greatly appreciated.
Thanks!
