22793 Discussions
Setting up dual extended monitors, 1 hdmi and 2 vga/hdmi adapter
SandyH1
HP Envy TE01-3254 works great with 1 Lenovo Thinkvision monitor. I have been trying to get a 2nd Lenovo Thinkvision monitor to work as well.
1. On my System display they both identify as #1
On Intel connected display, they both identify as #2
2.  Left monitor works, #2 monitor is black
3. Monitor 1 - PC HDMI to Monitor HDMI
 Monitor 2 - PC VGA/HDMI adapter to Monitor HDMI  black screen
Display card is updated
From Monitor 1 (left) - I can float an open tab across to the left but not to the right off to what would be monitor 2, but it's black
Monitor #2 works fine connected to my Surface Pro X Laptop tablet
Do I have to adjust the resolution to be more even displays? They aren't if I just leave them the recommended sizes.
Help!   See attached screen shot for system set up
Andres_Intel
Hello SandyH1,
Thank you for your answer, and for completing all the troubleshooting steps.
Before trying another adapter, I will start with an investigation to provide you with more troubleshooting steps
Andres P.
n_scott_pearson
Does Monitor 2 start to work if Monitor 1 is unplugged?
SandyH1
Hadn't tried that yet.... just unplugged Monitor 1 and nope, #2 still black screen.
n_scott_pearson
No, no, try powering on with only Monitor 2 connected.
SandyH1
Thank you, and yes after I updated to the below suggested graphic driver, I tried again to shut down and start with monitor #2 PC vga/Monitor HDMI with adapter - and it's still black screen.
Here is the adapter I'm trying to use.  Maybe this is my issue.
https://www.amazon.com/dp/B07XZ22KCD?ref=ppx_yo2ov_dt_b_product_details&th=1
Now my volume on different applications keeps increasing ...  which graphics driver is best with my system to switch to not have these volume issues?
Andres_Intel
Hello SandyH1,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you have no display issues with your Intel® UHD Graphics 770, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
SandyH1
Hi and thank you Andres,
I've tried several settings. At the moment they are both at 1920 x 1080 and both at 60Hz
I'm on Windows 11, I ran the scan on everything and have the report and saved and attached it, per your request.
Andres_Intel
Hello SandyH1,
Thank you for your response, it has been really helpful.
Please complete the steps below and let us know the results:
Andres P.
SandyH1
Well, thank you.  I tried both of those drivers and neither work.
Any other suggestions?  Can you suggest another adapter VGA pc to HDMI
How about a docking station with dual hdmi with extended view with USB-A or USB-c PC connection?
Can you recommend one for my PC system?
Andres_Intel
Hello SandyH1,
Andres P.
SandyH1
Thank you.  Do you have a fix for the driver so the volume doesn't increase by itself?
Andres_Intel
Hello SandyH1,
We have been working on the investigation, in this case, our recommendation is to try straight connections (HDMI to HDMI, DP to DP, VGA to VGA) adapter is converting the signal from analog to digital. For more information, you can visit Using Video Cable Adapters, Splitters and/or Docking Stations in Computers not Manufactured by Intel. You can contact the computer manufacturer for recommended adapters.
It seems this could be related to the adapter, just to make sure please test another adapter compatible with your computer.
Let me know the results.
If the volume issue is not related to the adapter, we recommend making a new post.
Andres P.
Andres_Intel
Hello SandyH1,
Andres P.
SandyH1
Hi Andres,
Thank you for following up.
Yes, it was the adapter in my case.  I ended up trying 4 different ones until finally got a USB /HDMI adapter working.
The volume issue was the the drive update that you had me try.  The adapter I purchased had a driver install and it's been working wonderfully.
You can close my case, I'm 100% working now.
Thank you.
Andres_Intel
Hello SandyH1,
Happy to hear that the issue is fixed, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
