22955 Discussions
Silverlight DRM issue with HD 4000 driver
JFeli5
I noticed I can't access any DRM content via Silverlight, so long as my Intel HD graphics driver is installed.
Have tried just about everything so far and have been googling the issue for ages - with no reuslts. The only answer I could find so far is that this seems to be an issue with certain graphics drivers for which there is no apparent solution yet.
I am using a Lenovo ThinkPad x230t (34372YG) with an Intel HD graphics 4000 chip and all the latest drivers and updates.
I have tried reinstalling/repairing the Silverlight installation multiple times, have reset the DRM cache, tried to stream content in various browsers (as administrator) and with different internet connections.
The only thing that seems to work is to uninstall the Intel graphics drivers - at least until Windows automatically installs the latest drivers, at which point it stops working again. So no real solution there, either.
This has become really frustratin, since I can't use a single Silverlight-based online streaming service from this machine.
Any help would be appreciated!
John
Current driver ver.: 10.18.10.3621
Computer: LENOVO ThinkPad X230 Tablet
CPU: Intel Core i7-3520M (Ivy Bridge-MB BGA SV, L1)
2900 MHz (29.00x100.0) @ 1997 MHz (20.00x99.9)
Motherboard: LENOVO 34372YG
Chipset: Intel QM77 (Panther Point)
Memory: 8192 MBytes @ 665 MHz, 9.0-9-9-24
- 4096 MB PC10600 DDR3 SDRAM - Kingston 9905428-051.A00LF
Graphics: Intel Ivy Bridge-MB GT2 - Integrated Graphics Controller [E1/L1/N0/P0] [Lenovo]
Intel HD Graphics 4000, 2112 MB
Drive: HGST HTS725050A7E630, 488.4 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: HGST HTS725050A7E6300, Disk drive
Sound: Intel Panther Point PCH - High Definition Audio Controller [C1]
Network: Intel 82579LM (Lewisville) Gigabit Ethernet Controller
Network: Intel Centrino Advanced-N 6205 AGN 2x2 HMC
OS: Microsoft Windows 8.1 Professional with Media Center (x64) Build 9600
Intel(R) HD Graphics 4000
Report Date: Sunday, August 17, 2014
Report Time [hh:mm:ss]: 9:50:13 AM
Driver Version: 10.18.10.3621
Operating System: Windows* 8.1 Tablet PC Edition(6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 7883 MB
Processor: Intel(R) Core(TM) i7-3520M CPU @ 2.90GHz
Processor Speed: 2893 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 2161.0
Current Resolution: 1366 x 768
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: LEN40e2
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 11.02 inches
Vertical Size: 6.3 inches
Supported Modes
1366 x 768 (60p Hz)
1366 x 768 (50p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE E2 40 00 00 00 00
00 16 01 03 80 1C 10 78 EA D4 E5 95 59 57 8B 28
20 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 76 1B 56 8A 50 00 0B 30 28 2A
32 00 15 9C 10 00 00 1B 76 1B 56 B0 51 00 0E 30
34 2A 24 00 15 9C 10 00 00 1B 00 00 00 0F 00 8C
09 32 8C 09 28 1E 0A 00 30 E4 D8 02 00 00 00 FE
00 4C 50 31 32 35 57 48 32 2D 53 4C 42 33 00 8C
* Other names and brands are the property of their respective owners.
Jose_H_Intel1
Hi John, the first suggestion here is to get the drivers from the system manufacturer's website because they were specifically designed for your system model. I recommend you installing them in this order: Intel® Chipset Device driver, Intel® Management Engine driver, Intel® HD Graphics driver.
Once you have installed all necessary drivers and restarted the system as prompted, try running the following test: http://web.sldrm.video.msn.com/d1/sldrm.html http://web.sldrm.video.msn.com/d1/sldrm.html
If more help is needed, kindly share the exact wording of the error, the Silverlight* software version used, and the URL or source of the video.
